Got my dyno run
Old Jul 11, 2009 | 09:51 PM
waldig's Avatar
Talking Got my dyno run
I got to run my car on the dyno at the Carlisle car show. For $80 you got to do two runs with results.
Iam happy to say that the results were as good as I had hoped. You can examine the torque and horse power as it is clear enough to see. What I was striving for and feel so good about is the Fuel / Air ratio that I was able to achieve with the NO TUNE controller that modulates the fuel rail pressure.
This has been in development for a while and netted me the best power to date. Next week I will be doing the manifold swap to see if the gains can be extended even more. The F/A ratio is almost ideal and is dynamically corrected as the car runs. Note that the line is flat at about 12.6 or 12.7 to 1.0.
The charts are curves and the numerical data back up to allow full evaluation. If you look closely you can see the air parameters on the chart as well as the other data points. It was a hoot and the dyno operators enjoyed doing the first Crossfire on that rig.
More data later, but for now I have a grin. THe pressure is now on to reproduce this design reliabily so that anyone can have their F/A mixture be tunable with a simple laptop and have that ratio be maintained over atmospheric changes in conditions such as heat and density.
Enjoy the weekend, WOODY
BTW the dotted line is to show the "IDEAL" f/a mixture as a reference............Oh and TAAAADAAAA
Old Jul 11, 2009 | 10:40 PM
tighed1's Avatar
Default Re: Got my dyno run
Dang Woody you nearly painted that dotted line!
Are you working on something that the rest of us will be able to get?
I gotta get mine on a dyno someday. Currently seeing 11.2 or so AFR at top of third gear. Guess its better to be rich than lean (on the roadster w/192 pulley).
Old Jul 12, 2009 | 01:00 AM
ProjectMayhem's Avatar
Your in the same boat as me 10.8 to 11.2 at redline. From everything i have read though 12.7 seems high for higher boosted applications, but i gues if the computer isn't pulling timing and the car is runing good no harm done .
Old Jul 12, 2009 | 06:12 AM
GDC-SRT's Avatar
Wldig,
Good numbers on the AFR, I know you have been chasing that control for a while.
Have you noticed a difference in temp readings?
Real world performance?
By holding the AFR higher, you should generate less heat in the motor, especially when pushing it hard.
Old Jul 13, 2009 | 04:35 PM
waldig's Avatar
Talking Re: Got my dyno run
There are no issues with heat as it does not affect the normal operation - only wide open throttle WOT operation requires it.
Real world performance is improved when you are pushing it, the upper range power is noticable. This is with the 185 pulley and the dual inlet CAI. I will be putting the much polished and long worked up manifolds on shortly for testing now that the baseline has been recorded.
More photos of the test are listed below. With my laptop I can now up or lower the desired set point of the f/a curve. You set the desired range and it holds that value as much as it can. You dont have to tweek each injector fuel "bin", your setting the computer f/a goal point with a few key strokes.
Enjoy, Woody
YES this is for every crossfire with or without the s/c. It uses a wideband f/a sensor and fuel pressure regulator..................off the shelf.
Old Jul 13, 2009 | 04:58 PM
GDC-SRT's Avatar
Sweet,
This should eliminate lean WOT for the mod bunch
Old Jul 13, 2009 | 06:18 PM
tighed1's Avatar
Off the shelf as in Off the shelf???
Now that's some good news!
Old Jul 13, 2009 | 07:01 PM
Squirrel Crusher's Avatar
Hurry up with those modified manifold results.LOL Squirrel Crusher
roar
Jun 15, 2022 11:46 AM
amx1397
Oct 2, 2015 05:20 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
Billy22Bob
Sep 18, 2015 08:57 AM
RacerXofFL
Sep 15, 2015 05:00 PM
