I have a few questions: Waldig
Old Aug 13, 2009 | 08:06 PM
waldig's Avatar
Question I have a few questions: Waldig
I wanted to solve a few problems that have been bugging me, my alignment is wearing out the slicks on the inside edge.
My camber is about 2.5 degrees and that is with factory springs. Iam going to make some adapters to reduce, adjust the angle so I have more control and less wear.
I will be doing the rear first cause I have a simple fix I THINK, for that.
1. What are the factory specs for the camber both front and rear and also the FRONT CASTER angle ???
2. Are there others that wish to reduce the angle?, I know Brian Black has already said he was.
Thanks Woody
Old Aug 13, 2009 | 08:56 PM
velociabstract's Avatar
Default Re: I have a few questions: Waldig
Wellllll, I want to increase the angel. This is what I found.
Les
Old Aug 13, 2009 | 09:10 PM
waldig's Avatar
Talking Re: I have a few questions: Waldig
What ANGel are you wanting and WHY?? I have poor tire utilization now, ps thanks. Woody
Old Aug 13, 2009 | 09:19 PM
I'm wearing my tires on the outside. They are shot. The fronts are to the cord on the outside edge. I guess I'm overdriving the car. I have very little camber in the rear and between -1.6 and -1.9 in the front. I'm on the trail of a good pyrometer.
Les
Old Aug 13, 2009 | 11:50 PM
ProjectMayhem's Avatar
i would love 0 camber in the back i keep wearing through tires to soon on the back because of the neg camber.
Old Aug 14, 2009 | 07:28 AM
waldig's Avatar
I need to know the measurments of the rear camber for your cars so that I can make a "kit " that will address the bulk of the population. I am thinking of not more than 1 degree negative on the rear.
Adjustable may happen but first I gotta get a prototype going.
My wheels are about 3/8" IN at the top when measured with a vertical level.. You can search on my posting looking at camber measurment. Woody
Old Aug 14, 2009 | 10:56 AM
Marine05's Avatar
Thanks Woody
Woody,
Here are the factory range specs for Camber:
Rear:-1.6 to -0.6
Front:-1.5 to -0.9
Here are the precise measurements:
ALIGNMENT SPECIFICATIONS
Front Axle Toe 2.5°
Rear Axle Toe 1.2°
Front Camber -1° 13’ (-1.22°)
Front Caster 5° 12’ (5.20°)
Rear Camber -1° 08’ (-1.13°)
Permissible difference in front axle camber between
right and left side of vehicle
20’
The answer to your second question I would imagine would be a "yes" from all the posts I have seen on this subject in the past.
Valk
Jul 12, 2021 09:49 PM
waldig
Jul 31, 2017 09:46 AM
waldig
Sep 17, 2015 10:35 AM
waldig
Sep 12, 2015 06:59 PM
waldig
Jul 20, 2015 08:10 AM
