dyno results
well im back from the mustang dyno at delk performance in lebanon tn.
the tech there did a good job running the dyno until we got good graphs and numbers. over all im very pleased!! on the downside the tech wasnt familiar enough with my engine to start pulling lines to show me boost numbers. :( and to top it off the ecu does not like to cooperate with a dyno! every time the car would get close to redline it would shift or shut down! major pain!:mad: so anyway after the first pull i logged 304 hp . 2nd pull netted 307 hp. let the car cool down and 3rd pull showed 323hp!! but the graph looked like a big turd! so cool again and 4th pull netted 311 after another shutdown:rolleyes: cooled it again and th 5th pull netted 321 hp!!!:p 317 ft/lbs of torque!!! this was way beyond my expectations. the tech thought 290 to 300 would be the best. monster motors!! temps were 75* 65% humidity. now its time for my c3 pulley (thanx jake!) and the search for the rite intake continues. hopefully by xmas my present to me will be a custom tne by eruocharged! as a side note i met john(jhm2k) and his lovely girlfriend hailey and jason (goodgenes79) and his energetic son at the car show fri. nite. jason srt-6 is awesome !! clean and fast sounds like a monster with the resonater delete! |
Re: dyno results
Excellent numbers!!! Wow that thing is a beast. Must be all the badging :p
Re: dyno results
cant wait until the pulley and intake are on. should be great numbers |
Re: dyno results
wow.you dynoed 321 and you're stock and on a mustang? geeze....must be the strongest stock M112k motor i've heard of.
Re: dyno results
Re: dyno results
That was 321 at 5800 rpm and look how it was still sky rocketing! I'll bet at 6000 you have 15 hp more.
Les |
Re: dyno results
Originally Posted by 32krazy!
totally stock with the exception of k&n filters. i know little of the types of dynos, thought the mustang dyno'ed higher numbers than most. but im really happy with the results. the weather and humidity were really working in my favor i believe. it was just a great day!
i believe generally its like this: dyno-dynamics < mustang < dynojet < dynapack though there is some variability between all dyno classes that may change this a little bit, and even within the same dyno class 32, was ur car in dyno mode? |
Re: dyno results
i think they are the second lowest reading dynoe.
i believe generally its like this: dyno-dynamics < mustang < dynojet < dynapack though there is some variability between all dyno classes that may change this a little bit, and even within the same dyno class 32, was ur car in dyno mode? 5800 was about the best we could get out of it. at 6000 rpm the ecu takes over and shuts it down. to close to the redline is my guess. im sure with a tune it could do better now a little off topic. im installing the c3 pulley. there are 3 shims from the stock pulley and jake sent 2 more with the c3. added all 5 and still cant get .20 mm clearance for the pulley. is this normal? im going to see if i can find a shim kit but mite have to wait until mon and call jake for some more shims. ballpark it looks like there is approx .50 mm diff. between the stock and c3. any input? |
Re: dyno results
Those are some great starting numbers. I would stick with the 307 for a stock number, but that is just me. Now to get that pulley on and work out you intake issues to get some better numbers.
It was great meeting Steve and John and Hailey at the show. Didn't have much of a chance to look at other cars between answering questions about what mine was and talking with the forum buddies. John, Hailey is gorgeous and seems like a real catch, so you better get an SRT soon... you know just to show her how much you care, lol. Great time last night and great numbers for the dyno. |
Re: dyno results
It says "with WCF" what does that stand for, and what is it? And I thought mustang's dyno'd low, am I wrong? which would mean you still have more.
-steve |
Re: dyno results
Re: dyno results
Steve, I'm with Turkel; those numbers are sick the more I look at 'em. Can't wait to see drag #'s :cool: |
Re: dyno results
Originally Posted by ckovach
As long as it's not rubbing and you have a little bit of clearance at the closest point you should be OK. I think mine ran at 0.14 without any issues. In general, you want it as close as possible without rubbing.
Re: dyno results
Well that's all rather interesting...I thought that our engines usually netted around 280-290 stock.
Maybe there IS something different about the 32? |
Re: dyno results
Re: dyno results
seriously though, I'd love someone knowledgeable to comment on this.
seems off to me. 321 at the wheels would mean 385 BHP. That seems a little wild for stock. I made 280 with the needswings intake on a dyno dynamics....since then I added the code 3 pulley, and run mid 12s, so my car isn't abnormally weak or anything... |
Re: dyno results
seems off to me. 321 at the wheels would mean 385 BHP. That seems a little wild for stock. I made 280 with the needswings intake on a dyno dynamics....since then I added the code 3 pulley, and run mid 12s, so my car isn't abnormally weak or anything... i do know that it seemed if he set the mph numbers higher it ran better. ie: first pull logged from 94 to 110 last pull logged from 115 to 158. dont know if it made a difference but the ecu seemed to like it. revs at 6012 and the ecu shifts the car into overdrive or shyt it down. 5800 seened to be the magic rpm of course aussiedude it could just be the badging!!:rolleyes: :D |
Re: dyno results
I don"t mean to be a wet blanket on this topic but it seems this board goes through this discussion every few months. Some one decides to dyno his car and the debate of the dynos begins again. To me this debate of the dynos has little meaning other than bragging rights. To the victor goes the spoils. The only way to compare cars is on the track. What is your 0- 60 time? What is your 1/4 mile time? ,etc. Those are the only numbers that count. It does no good to have a million horse power engine if you cannot translate that into speed. Get on the track and find out ! BTW I am very jealous of your numbers so far:p
Re: dyno results
as for 1/4 mile times the closest track is bowling green ky. i have never dragged at a track before and need more info before i go. and im waiting till the weather cools a bit to give me every edge i can get!! :rolleyes: ballpark my 0 to 60 times are in the high 4 sec low 5 sec, but thats just a stopwatch and chalk line on a road by my house. |
Re: dyno results
-steve even if i dont use the wcf i still managed 311hp |
