Anyone have lifter or rocker arm trouble?
Old Aug 30, 2009 | 08:48 PM
H.K. Phooey's Avatar
Default Anyone have lifter or rocker arm trouble?
I still have the ticking sound, it appears to be just under the valve cover on the drivers side. I will pull the covers and peak around, has anyone ever had an issue with this part of the engine?
please kill the other thread.
Old Aug 30, 2009 | 10:41 PM
Voyager's Avatar
Default Re: Anyone have lifter or rocker arm trouble?
https://www.crossfireforum.org/forum...-w-part-s.html
this is the most recent thing ive heard about it, i sent my car into the dealer for ticking and they said it was normal, but it sounded like it helped the person in the link.
Voyager's Avatar
if you search for lifters on the forum youll find a bunch of links to ticking, you might want to see if they have the same symptoms
Old Aug 30, 2009 | 11:47 PM
ProjectMayhem's Avatar
Just FYI my car is extremely quiet no ticks, i had a slight bearing noise you could only notice once you opened the hood. Turned out after i took off my belt today and spun all the pulley's around that the idle pulley was starting to wear/fail on my 178 pulley setup.
19k mileage, lifter tick is not normal but not really a reliability issue just annoying.
Old Aug 31, 2009 | 07:47 AM
32krazy!'s Avatar
sorry to jack the thread but felt it was important. if you find any pulley with bearing wear replace it immediately!!! dont wait for seizure to cost thousands of dollars for a 40$ pulley. heres a great thread with part numbers and video. while changing my s/c pulley i inspected all the pulleys. 3 pulleys inc. the s/c pulley all had signs of bearing failure. my cost for 3 bearings was under 100$ and im sure saved me $$$$ if any 1 of them failed lunching the water pump s/c shaft or ping ponged around the engine bay
*STOCK C32 / M112K owners: Check your OE Idler pulley!!!* - MBWorld.org Forums
Old Aug 31, 2009 | 10:29 PM
That is a great write up and tells me this sounds like a lifter problem.
Old Aug 31, 2009 | 10:34 PM
BlueStorm's Avatar
could there be issues with the lifter buckets not getting enough oil pressure under indle conditions?
without proper pressure they may slack up, I have no idea how this system works, just guessing
Mike OD
Sep 23, 2016 07:00 AM
RojoGTO
Feb 6, 2016 11:14 AM
velociabstract
28
Oct 28, 2015 12:46 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
FISHBONE
Sep 17, 2015 06:15 PM
