tell me what you think
Old Sep 7, 2009 | 04:06 PM
xbcyrus's Avatar
Default tell me what you think
both crossfires i have need new rear tires, i am thinking about getting 255/35 19 Bridgestone potenza runflats with 80% tread left for my limited xfire and micheline ps2 285/35 19 with 65% tread left for my srt6 coupe....all 4 for 140 plus 40 to get all 4 installed and balanced, should i grab it? i think so
Old Sep 7, 2009 | 04:13 PM
fastfunfor2's Avatar
Default Re: tell me what you think
Sound like a good cheap way to learn about other brands. Could those 285's be a tad bit wide? There is another thread up today that says 275s are as wide as you should go.
Old Sep 7, 2009 | 04:15 PM
xbcyrus's Avatar
well i went to a couple tire places that are well known and they said i honestly could go easily with 275 and 285 for my rear, they said even 295 is fine but that might be pushing it a lil but anymore than 295 is not good to do
Old Sep 7, 2009 | 04:39 PM
dwightdmagee's Avatar
Banned
You can go just about as fat as you want up to 285/35R19 in the rear on the 9" wide rim. A 295 on the 9" is a little dicey. The front's should be limited to 235/40R18 as not to rub the control arm nuts. Yikes.
The Bridgestone Potenza RE760 is a nice tire, but I'm not sure how happy you'd be with the run-flat version. Sure can't beat the prices, tho, especially the mount/balance cost - sounds to good to be true.
Good luck with the deal.
Old Sep 8, 2009 | 10:03 PM
KrzyFast's Avatar
My 235/40/18 Nitto Invos were really close (less than 3/16 inch) to the front A-Arm nut. I put 10mm spacers on there for peace of mind.
Just my $.02.
Cheers,
KrzyFast
Old Sep 8, 2009 | 10:46 PM
SRT-6 Steve's Avatar
Do not put 295's on stock rear as they will not wear properly nor be safe. They will buldge quite a bit greatly reducing the contact patch.
Old Sep 9, 2009 | 02:40 AM
SRT SIX's Avatar
I have been running Nitto Invo 285x30x19s on the rear of my SRT6 stock rims for almost 2 years (including some autocross runs) no problem and no uneven wear
On the other hand, not sure how the mix of the run-flat rears with the non run flat fronts might affect handling.
