High MAP code
Old Nov 19, 2009 | 04:02 PM
Xray's Avatar
Default High MAP code
Well I was on my way home from the track last night and hit a section of open road so I decided to jump on the throttle a little and ran up to just above 100mph and then backed off. All of a sudden my check engine light comes on. I listen close and just feel the car to see if anything is abnormal but it seems to be purring smoothly. So I punch up the diagnostics on my dashdaq and it tells me that I have a Manifold Absolute pressure to high warning. I cleared the code and finished the ride home which was about 10 miles uneventfully. Just curious if anyone else has had this happen. I do have the 181 pulley. Thanks in advance for the help.
Old Nov 19, 2009 | 04:07 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Default Re: High MAP code
A few people have seen this....high RPM, cooler weather...TOO MUCH BOOST. Time for a MAP clamp.
Old Nov 19, 2009 | 04:09 PM
Xray's Avatar
What the F*** is a MAP clamp
Old Nov 19, 2009 | 04:13 PM
MikeR's Avatar
I have the 181 pulley also and have had the high MAP code a couple of times at the track....
Old Nov 19, 2009 | 04:15 PM
Xray's Avatar
Well then I will take this as confirmation that the pulley is giving me the increase I wanted. COOL
Old Nov 19, 2009 | 08:13 PM
32krazy!'s Avatar
make sure to mention this to tony when you get the dyno tune. he may be able to compensate for it. im also checking on delimiting and -10 fan mod
Old Nov 19, 2009 | 09:33 PM
Xray's Avatar
Great I def want the fan mod since I live in florida where it is hot hot hot.
Old Nov 19, 2009 | 11:38 PM
ProjectMayhem's Avatar
Whats the max for the MAP sensor? Map clamps are bad... just remember how much this mtor costs to replace... a map sensor able to read more boost is the safest way let the ecu do its thing.
Old Nov 20, 2009 | 12:20 AM
cruzinquick's Avatar
datalog datalog
Old Nov 20, 2009 | 11:01 PM
Adamsrt6's Avatar
Has anyone changed their map sensor?
Valk
Jul 12, 2021 09:49 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
TOPLESS
Feb 9, 2016 11:28 AM
Oct 1, 2015 01:42 AM
ala_xfire
Sep 28, 2015 05:51 PM
