Planned modifications on my SRT6
Old Nov 24, 2009 | 03:30 PM
Hurricane's Avatar
Default Planned modifications on my SRT6
I have planned to perform the following three modifications:
1) Needswing intake kit (single pipe)
2) Code3 pulley
3) ECU tune
My question is: What can I expect for increase in RW horsepower from stock.
I only plan to perform these mods and nothing more. I look forward to your response. Also, I'm budgeting $2000.00 US, is this reasonable?
Old Nov 24, 2009 | 03:59 PM
distantpulse's Avatar
Default Re: Planned modifications on my SRT6
2) Code3 pulley
3) ECU tune
I may be selling my code3 pulley if you are interested......Might save you a few $.
Old Nov 24, 2009 | 04:01 PM
///SilverSaphRT6's Avatar
Why?? For sommmmething better...and how much $ ^^^^^^^^
Old Nov 24, 2009 | 04:02 PM
Well, honestly.....If all goes well with my meth setup, I will not have room to run the car stacked anymore and won't have a use for it. I will know more in a couple weeks to come......It has been sitting in a box....lonely. :P Price?? Make an offer I guess.....
Old Nov 24, 2009 | 04:04 PM
ZAHANMA's Avatar
I may be selling my NW Single Intake within 6 weeks (fingers crossed)...I will definitely save you some money.
...however, yes $2000 is WAY more than you will need to accomplish those modifications...the problem is actually stopping after you start.
1) Intake - $500 for NW Single
2) Code 3 - $500 from HPAutoworks...
3) ECU Tune - $600 from Eurocharged...I assume about the same if you go InMotion.
...that is if you purchase all of those brand new.
Old Nov 24, 2009 | 04:11 PM
32krazy!'s Avatar
were are you located? tony is doing custom tunes for us in atl on 12/12. 1 slot left!! heres a chance to mark 1 of those mods off the list
Old Nov 24, 2009 | 04:37 PM
you can except close to 340 to 350 hp at the rear wheels(each car is defferant) that would put you in the 12.5 to 12.8 ,,,1/4 mile run.
Old Nov 24, 2009 | 04:40 PM
BLKFIN's Avatar
ADDICTED TO BOOST
2) Code3 pulley
3) ECU tune
With those exact mods and some good cool weather, you will see 350hp and low 12s. I had that for a while and saw 343 hp in the 90 degree summer dyno pulls and 12.2 1/4 mile runs in the winter...
Old Nov 24, 2009 | 05:11 PM
Thirteendog's Avatar
What kind of horsepower are we pulling with a stock setup?
Old Nov 24, 2009 | 05:30 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Mine base lined at 280ish at the rear wheels on a dyno jet. There are so many variables from each car to car and each operator it is useless to compare. You can see a different reading based on outside temps, humidity, engine temp, dyno type, and operator of the dyno. You can even see a difference on the setting of the dyno on the same pull. At the end of the day, the dyno numbers mean nothing…only the time slips from the track do
Old Nov 24, 2009 | 05:38 PM
Agreed. The only thing dyno's are good for is to fine tune the car.
Old Nov 24, 2009 | 06:01 PM
MikeR's Avatar
You guys have been listening to Cruzin too much!!
(even if it is true)
I wonder if a C3 pulley would fit on my SSB????? No, No.... stop that...get away from me you devil.....
Old Nov 24, 2009 | 06:02 PM
Bulldogger's Avatar
There are just as many variables at the track, weather DA/Humidity/temperature/ sunny or overcast, plus track prep,and tires.
Old Nov 24, 2009 | 06:06 PM
Hurricane's Avatar
350 RWHP is more than I need. So I would say, crankshaft HP will be around 410 HP based on a 15% loss (280RWHP/330CHP).
The car is currently in central Mexico. San Antonio is home though. Once moded I will be testing how fast the SRT6 will go, lots of good stretches of highway to Monterrey. I've already done 160 mph limited but once I take away the limiter I will take this car to its limit. Probably in the new year when the temps are cooler, 60-80 F. No worries, to prove it I will be taking video. Last time I took a photo, hand held.
FYI, I will be buying new parts but thanks to those who have offered.
Cheers.
Old Nov 24, 2009 | 06:12 PM
BLKFIN's Avatar
ADDICTED TO BOOST
You are correct...at least the dyno does not care how much you weigh....LOL. All that talk of DA and stuff at the track is just an excuse for why someone is not in the 11's yet..LOL...FLAME ON!!!
Old Nov 24, 2009 | 10:54 PM
Bulldogger's Avatar
so I guess it is safe to say you run consistantly in the 11's
Old Nov 24, 2009 | 11:19 PM
mrphotoman's Avatar
here we go with that silly overhyped da crap again lol.
as already mentioned, there are lots of things that can cost you time at the track.
anyway, back on topic. i think the OP has a nice list of mods to go on his car and will be under budget with that setup.
Old Nov 25, 2009 | 09:56 AM
If the DA of your right foot is within .03576 % of the DA of your left front tire, you will run .5 better in the 1/4. FYI........
Old Nov 25, 2009 | 10:14 AM
cruzinquick's Avatar
[/SIZE] so I guess it is safe to say you run consistantly in the 11's
Dang you owned him there. No one has hit 11's just on the C3 pulley and they never will. Yes that's a challenge for you C3 loyals. Don't forget to mix infamil to fill your bottle!!! LMAO.
Remember DA is only to compare your car to another at every incremental measurement on the track. 60', 330', 660', 1000', 1320'...if you don't have drag radials and you can't drive then it's useless. If your never going to hit the track then your only resource is to dyno. That doesn't mean you can't datalog on a lonely stretch of road, and give those results to your tuner and see if you need any tweaking.
Most importantly dyno or datalog on the coldest day available and still safe to run the car all out through 3rd. On that coldest day, not by coincidence will have the lowest DA of the year and will have the thinnest air available. This will be the day your tune will lean if it's going to. If tuned to that air anything warmer than those conditions you will have a completely safe tune barring part failure.
Old Nov 25, 2009 | 10:43 AM
billvp's Avatar
The Code3 pulley price went back up, but yes TS, even if you pay someone else to install the items you can get in under $2000 with what you've chosen.
