need help looking for ecu wiring diagram in the service manual !!!
Old Dec 13, 2009 | 12:23 AM
amgstyle's Avatar
Default need help looking for ecu wiring diagram in the service manual !!!
hey guys i looked over the srt service manual but can't find wat i was looking for. i'm looking for the wiring diagram for the ecu. i need to install o2 simulators but don't want to tap right next to the o2 senor under the car near the exhuast. i wanted to tap into them under the hood. i looked thru the service manual but can only find the wire diagram for the 02 sensor itself. please help. also what is the difference when the say upstream and downstream for the 02 sensors. i need to tap into the rear o2 sensors between the 2 cats (or the ones closest to the muffler) thanks.
Old Dec 13, 2009 | 01:41 AM
MikeR's Avatar
Default Re: need help looking for ecu wiring diagram in the service manual!!!!
SRT6 service manual section 8W
Oxygen Sensor 1/1 Upstream . . . . . . . . . 8W-30-7, 8
Oxygen Sensor 1/2 Downstream . . . . . . . . 8W-30-10
Oxygen Sensor 2/1 Upstream . . . . . . . . . 8W-30-7, 8
Oxygen Sensor 2/2 Downstream . . . . . . . . 8W-30-10
have fun.....
Old Dec 13, 2009 | 02:17 PM
amgstyle's Avatar
Default Re: need help looking for ecu wiring diagram in the service manual !!!
wat does it mean when it says upstream and downstream?? also that show's the wire diagram of the o2 sensor itself i was looking for the wire diagram for the ecu. i want to tap into the o2 sensor wires but not from underneath the car but from under the hood near the ecu. thanks for the fast response back.
Old Dec 13, 2009 | 02:30 PM
downwardspiral's Avatar
upstream (before) and downstream (after) of the cat.. I have the ecu pinout page number on a postit at home.. Use the search function on the pdf reader, search for ecu pinout.
Old Dec 13, 2009 | 03:34 PM
amgstyle's Avatar
thanks. i just searched for ecu pinout but nothing was found
Old Dec 13, 2009 | 05:33 PM
Pages 1524 to ~1530 in the .pdf file shows all the PCM connectors, with every pin numbered with a description, color of wire and gauge of wire. That's why nothing came up, its a powertrain control module, not an ecu .
Old Dec 13, 2009 | 06:05 PM
MikeR's Avatar
Page 8W-30-6 shows the connections of the upstream O2 sensors at the PCM.
C3 pins 6, 7 & 23 and C2 pins 15 & 24.
And page 8W-30-8 shows the connection of the downstream O2 sensors.
C4 pins 5, 15 & 16 and C5 pins 1 & 4.
Not to be snide. But if you cant read the schematics, please dont do any mods to your wiring.... you could mess up you car badly.
Old Dec 13, 2009 | 06:21 PM
32krazy!'s Avatar
+1 mike. he is posted on 3 different forums and is still having issues understanding the diagrams. let an indie shop do this mod!
81's
Sep 13, 2015 04:34 PM
bobbie
Sep 12, 2015 12:49 PM
RiderJC
Sep 7, 2015 11:19 PM
jaesa
Sep 7, 2015 01:50 PM
sk8erjosh09
Sep 4, 2015 09:24 PM
