Nitrous & Meth
Originally Posted by AIS
Looks good. Are you going to get it tuned?
Rodney
By the way. Have you seen our new competition trunk mount tank?
Rodney
Eventually I will get it tuned and dialed in.
I need to figure some other things out first.... I wish I would have bought your comp trunk mount kit! It is a hell of a lot nicer than my AEM kit!
oh well, I guess it does the job. Doesn't look nearly as nice though. Lol :P
Rodney
Features Include The Following:
*3 gallon capacity
*Dimensions are 14" long (not including the 1.25" rear sump) by 10.5" wide by 7.5" tall
*Aircraft style locking cap with built in flapper vent.
*Large cap allows you to access the inside for those who want to stuff the tank with safety foam
*Built in virtual sump with dual 3/8 npt rear pick up's
*Dual pick ups allows the use of a second pump for our high horsepower guys who max out one pump - sounds crazy but it happens!
*Pump is reversed under the tank for a clean over head appearance
*Reversing the pump under the tank allowed also to also break up the floor of the tank to help control fluid slosh
Originally Posted by oledoc2u
I like the set up....this is on my list to do now....nice job...
I believe that is AIS doc... it sure does look good dosent it? I was thinking small hidden tank, but that one looks so good, I could be convinced....
I wonder if you can get a pop can in it??
Thanks buddy. This tank has been a big hit and really looks great every time you look at it. If you want a tank give me a call and I can make you a deal on one. We now have red and black caps available too.
Rodney
*3 gallon capacity
Rodney
*3 gallon capacity
Wow man! That is sweet looking! That is not the one I thought you were referring to. lol. I thought you meant the one Mrphotoman had. Does it come with the pump or would I be able to just use the tank and my pump/fittings/hoses? In other words is it an easy swap? Is my AEM pump larger? I am not sure it would fit under there? I would like this sitting in the trunk much better than my current setup. Give me some more details and PM me a price if you can.
Stage 1 trunk mounts $349.99
Stage 2 trunk mounts $475.00
These prices will go up next week once they are in stick again. Let me know if you have any other questions or how I can help.
Rodney
Yeah, all new tanks. Just received them a week ago. Were sold out and have another shipment of tanks coming in tomorrow. We will have system ready to ship on Monday. We are running a special, $70.00 off, on the systems currently as we our out of stock on them.
Rodney
Rodney
So I would need to buy the whole system to get the tank? I would consider just buying the tank and hooking it up to my system if possible? Not even sure that is an option?
Rod,
Rodney
I wonder if you can get a pop can in it??Rodney
Hey Kolevski,
I have a ZEX wet N2O kit purchased at Eurocharged during my tuning week at the their shop.
It was installed by one of the Euro…. techs prior to the last two days of tuning and is spraying through the SC. I have two custom Dyno tunes (Tony at Eurocharged) maximized for both running with N2O and the second tune without N2O for everyday use (tune currently installed) so pulling back the timing has been a challenge. We were originally going to have a dual tuned chip installed but I think the cost was an additional $900. you can ask Jake about the Chip if you’re interested. I only planned on using the N2O at the track or the occasional spirited race so spending $900 just to switch between tunes was a little high for me to justify. Running the NOS tune was not an option for daily use since it pulled the timing back too much.
Just remember you will need to pull at least 5-6° from your timing if you run a custom tune so watch you’re A/F , generally it’s around 1° of timing per 50# shot.
I’m able to retard some timing and safely run 35#-50# shot (pending on what fuel I’m running) but anything more and my knock sensor count escalates upward unless i'm running 100-104 race gas.
My times have not been posted on Drag times yet, but I have Jeff Croy’s time in my crosshairs, I’m having major traction issues between the 60’-140’ area around the time the N2O is activated. My concern is pulling additional timing reliably enough to confidently use 75#. Now I’m thinking about using H2O/Meth setup to reduce the chance of detonation throwing the 75# w/slicks for my next trip back to the track this spring. Just waiting to read up on OleDoc’s report on the Meth system he is installing before I jump in.
Good Luck
Good Luck
Originally Posted by Mimi05SRT6
Why does my owners manual say not to use methanol?????
Rodney
Originally Posted by tri_zombie
Hey Kolevski,
Good Luck
Good Luck
