Squeak coming from rear of car?
Old Jan 23, 2010 | 06:48 PM
cross><hair's Avatar
Default Squeak coming from rear of car?
Now that we are in the colder months of the year, sounds seem to be amplified. I don't know if it's literally due to the lower temps and/or the fact that I drive with the windows up with allows me to hear things more clearly.
I've been noticing on take off I hear a little squeak or chirp come rear of the car. I don't believe we have a limited slip, so maybe it's the shocks? It does it on a normal slow takeoff.
Once the car is warmed up I don't hear it- that's the odd thing (if it is suspension related).
PS OT but my seat heater on my driver's side doesn't work. Apparently this malfunction is common. Does anyone know what exactly goes in them that make them stop working. Is it something I could order the part for and do myself? Is it worth paying a dealer to fix it- considering it could go bad again and there are very few days cold enough that I'd use it consistently. Thanks in advance everyone!
Old Jan 23, 2010 | 08:00 PM
32krazy!'s Avatar
Default Re: Squeak coming from rear of car?
cant help with the squeak but the seats are very common. theres a repair kit but is fairley involved. the elements are sewn into the seat cover so the dealer will only replace the cover. i think 700$? search the forum theres an in depth thread on the repair.
Old Jan 24, 2010 | 01:23 PM
DTMenace's Avatar
Do you use your emergency brake when its parked? If so, this could be the culprit. Try not using the EB the next few times, to test this squeak issue. This has been reported in the past by some owners. Just my 2 cents....
Dennis
Old Jan 24, 2010 | 10:10 PM
Unfortunately no, I actually never use the e-brake.
Old Jan 24, 2010 | 10:18 PM
32krazy!'s Avatar
may be a bushing that is squeking
Old Jan 24, 2010 | 10:27 PM
Good call- sounds quite possible. Are they lubricated at all?
Old Jan 25, 2010 | 08:44 AM
32krazy!'s Avatar
not like you want!! no grease fittings. some are oil filled. if it leaks out you could be getting the squeaking
Old Feb 1, 2010 | 01:03 PM
JHM2K's Avatar
Maybe it's this...
Old Feb 1, 2010 | 05:21 PM
MikeR's Avatar
I just threw two of those in the trash..... they like to sit on top of my SC and eat things.....
Old Feb 3, 2010 | 12:45 PM
goodgenes79's Avatar
I am getting like issue but from the front. When I take off from a dead stop, I get a slight squeak, from a control arm maybe? I noticed while under the car that the boot for the control arm was flat, meaning it was not holding any lubrication, and noticed the lack of grease fittings. I was going to send it up to have it inspected while replacing the steering stabilizer, which is leaking, but thought I would try here first.
Old Feb 3, 2010 | 01:00 PM
I get a similar squeak from the front but always thought it was the supercharger clutch engaging for the first time. ???
Old Feb 3, 2010 | 02:10 PM
Did you recently get new tires. If so, the tire jocky may have overtorque the lug bolts. Or simply tightened them up improperly.
It warps the rotors. Just enough to occasionaly kiss the pads.
I have an intermitent squeak from the rear. It is the cause. I'm saving up for a full set of slotted front and rears when I change out the pads this spring.
roadster with a stick
Old Feb 3, 2010 | 06:08 PM
Mine squeaks as the front raises slighty for take off. I am not accelerating fast, just moving through the light, but everytime I hear a squeak. i am assuming it is the wheel hub/A-arm moving up on the control arm fitting.
Old Feb 3, 2010 | 11:39 PM
ProjectMayhem's Avatar
I get a squeek as well. but i use my e-brake everytime i park so im not putting pressure on the parking rod in the auto. Just happens the first time you tap the go pedal. I'm at 25k and i would begin to bet some of the rubber bushing are already begining to wear. wonder if any polyurethane kits are available for the crossfire yet...
Old Feb 4, 2010 | 12:07 PM
I was thinking the same thing. Poly bushings would be nice. Wasn't Waldig putting together a list of replaceable/upgraded bushings?
rayth
41
Jul 31, 2019 04:02 PM
WindRestrictor
Jun 16, 2015 12:18 PM
rmcdaniel12
Jun 10, 2015 03:51 PM
WindRestrictor
Jun 1, 2015 02:31 PM
Emil
Aug 18, 2003 09:35 AM
