New Crate engine for SRT6
Darn it, three months ago I came across a complete Crossfire on our local Bay Area Craigslist for only $900, it was missing just the engine and trans.
Nice find.....I wish I was f''n loaded $$$$$$$$$$$$$$$$$$$$ I'd buy them all!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by tighed1
Is this a 100% drop in replacement for our engines (SRT) or will there be issues?
Smart guys?
Smart guys?
Originally Posted by 32krazy!
dj its a drop in but not sure how you get it to work without the matching ecu
Without electronics there is nothing for the ECU to read that it would object to. The only possibility would be the throttle body. But I know that isnt a problem since I switch mine between the SSB and Aero with no issue. Just curious.....
Originally Posted by MikeR
Krazy, Since it is the engine only and no electronics, shouldnt any SRT/SLK32 ECU should work with it??
Originally Posted by RL-2005
did you guys see the little plaque that shows who assembled the engine? most have a blank spot there correct?
Originally Posted by Buggin
That's actually the AMG built MB version. After 2002, they have the builder plates on them.
and he is selling these engines as chrysler engines not mercedes engines.
just kind of a neat thing that i noticed.
I want to see the New Crate engines in person. Where can I look them?
i was thinking the engine is tied to the ecu by vin #. the ecu is specific to the car by vin and engine to the car by vin. could be wrong i have been before!
If you took the ecu, sensors, injectors, etc from your existing motor and swap them to the new motor it should fire right up. When you change the engine to something different than what was stock (v8, NA to SRT swap) all the electronics would need to be carried over to the new engine and be programmed to the car.
I agree with MikeR, I would think it would be just a drop in since all the factory electronic components are the same from ( stock ) engine to engine you dont have to relearn a cps, a new fuel injector, a throttle body, a new iat sensor, or any thing else you would replace if it had failed and match it to your ecu. I have never heard of the ecu being vin matched to the motor other than being matched to the original design functions of the cars particular electronics, as in like a V8 ecu v/s a V6 ecu.
