Solve an argument
Old Aug 22, 2010 | 10:14 AM
Thirteendog's Avatar
Default Solve an argument
Steve and I are having a spat and I would like for you to get in the middle of it. On the way to church this morning and doing my early morning speed run. This morning I hit 160, and 32krazy says that's impossible because the SRT is limited to 155. I know I'm not the only one to hit these speeds, so solve our squabble what's the fastest a non tuned, SRT-6 with a NW DCAI? I say 158 +/- 2mph
Old Aug 22, 2010 | 10:17 AM
danimal's Avatar
Default Re: Solve an argument
Easy solution........take Steve for a ride!!!!
Old Aug 22, 2010 | 10:42 AM
All limiters aren't equal. I bounced off 160 before it cut out before my tune....but, I like the idea of taking him for a ride. I had a buddy with me when I did it....witnesses you know, and he wasn't saying much until we back down to 55...lol...
Old Aug 22, 2010 | 10:50 AM
Haha Steve's having Internet issues so he can't chime in.
Old Aug 22, 2010 | 11:04 AM
andrew's Avatar
-C-I-C-C-I Associate Member
the cars speedometer is usually off quite a bit at those speeds.
Old Aug 22, 2010 | 11:06 AM
Bladecutter's Avatar
A lot of German cars will have a different reading on the speedo for you to see, in comparison to the vehicle speed that the ECM sees.
Porsche is infamous for this, for example.
Above 10 mph, by Boxster has a 4 mph speedo reading above what the car's computers are actually determining from the transmission input, and the wheel speed sensors.
You can actually hook up a diagnostics tool to the car, and read the actual speed reading, and see its 4 mph off anytime you choose. You can actually pull up the various sensor data using the HVAC controls in the car, and see the difference that way, too. (yes, its pretty cool being able to pull up different sensor data right on the hvac controls).
So yes, I would imagine that you would be able to get the speedo to read 160 on a Crossfire, before hitting the speed limiter.
BC.
Old Aug 22, 2010 | 11:11 AM
Easy way to settle this. Pick the right spot,do the deed, and then have the officer show "Steve" his meter.
End of argumet no?
Case Closed
franc
Old Aug 22, 2010 | 11:55 AM
Damage Control's Avatar
While not stock, this guy got his up to 162. Take a look.
Old Aug 22, 2010 | 12:02 PM
MI1XFIRE's Avatar
You can also use a portable GPS like the Tomtom to verify how much your speedo is off. If I remember the SAE requirements it can't be off more than 4% within normal operating range.
Old Aug 22, 2010 | 12:57 PM
Montana Crossfire's Avatar
Actually I had my Limited to 158mph (speedo) before the tune I had always heard the cut off WAS 158?
Anyway I have the GPS mounted for whenever I am doing high end runs.
Both can be off to an extent! Yes even the GPS, but, the GPS is the closest to accurate.
173mph to date but I truely believe near 190mph is possible.
HAPPY HIGH END!
Mike
Old Aug 22, 2010 | 04:37 PM
ModlessG's Avatar
My speedometer is spot on at the track if it says 102 through the traps that is exactly what the time slip says. I would assume at 160 its still pretty close. Now my motorcycle is another matter. If it reads 70 mph Im going 63.
Old Aug 22, 2010 | 05:58 PM
kingkub57's Avatar
I have notice with my Garmin it reads faster than the speedo does about 2-4 miles different, but never the same, and again all speedo's can have 2 to 7 miles phr difference in accuracy, and have read a lot of threads/post about going 158+ with no problems and stock as well.
Old Aug 22, 2010 | 06:41 PM
Erzer's Avatar
Similar experience, but I've only noticed it off by 2 mph. Still I think it would be good enough for this "argument".
Old Aug 22, 2010 | 06:58 PM
JHM2K's Avatar
The only thing that's not possible is for his SLK to get more attention than our Crossfires.
Old Aug 22, 2010 | 07:23 PM
Bigkid's Avatar
Nick, check your tires and make sure you are good to go on thoes morning speed runs. Enjoy the play time but be safe.
Old Aug 22, 2010 | 07:29 PM
Buggin's Avatar
LMAO... Hey, he's passionate about his car.
Old Aug 22, 2010 | 07:38 PM
JHM2K's Avatar
And rightfully so, it's a beaut.
I just remember him being butt-hurt about Bob Morgan's car stealing the show at the drag strip, hahaha....
Old Aug 22, 2010 | 07:43 PM
Buggin's Avatar
Yeah, sorry I missed that... I was out of town.
It's ok, Bob get's the looks when I go out to the track with him... but I'm still quicker. (sorry Bob)
Truely, this is why I like meeting up with these guys... always some good smack talking amongst friends!
Old Aug 22, 2010 | 07:46 PM
JHM2K's Avatar
Only the best smack-talk available!!
Now if we can only get Nick to use the proper drain pan in Steve's garage...
Old Aug 22, 2010 | 08:16 PM
Green, yellow, and black sheesh. So freakin confusing.
Big kid thanks for the warning. I actually aired them up to 34 lbs last night. It also was cleaned and waxed last night
