Fitment of 18" rear rims on srt6 ??
Old Oct 24, 2010 | 09:54 AM
ModlessG's Avatar
Default Fitment of 18" rear rims on srt6 ??
I bought a set of snow tires with rims from tire rack. The rears are 225/45/18 there is something making a clicking noise from the back with these tires on.I just backed out of the drive way it sounded awful. I cannot find where they are rubbing. Is anyone running 18" rear tires?? thanks
Old Oct 24, 2010 | 11:22 AM
Default Re: Fitment of 18" rear rims on srt6 ??
sounds like the lug bolt was not for that rim and went through and messed up the parking brake cable and other brake parts. good luck,,, jim
Old Oct 24, 2010 | 11:29 AM
ModlessG's Avatar
Tire rack sent me lugs with the tires that were suppose to fit they also had centering rings for the wheels. What should I look for on the brake cable?
bmorgan's Avatar
+1 Sounds like the bolts are too long. Probably destroyed the eBrake.
Old Oct 24, 2010 | 12:01 PM
NeedsWings's Avatar
grab a stock rear wheel, stick the stock lug thru it, measure the distance it protrudes
grab the new rim/spacer/lug and do the same to compare
Old Oct 24, 2010 | 12:05 PM
waldig's Avatar
Red face Re: Fitment of 18" rear rims on srt6 ??
I run 18s and race. Your studs are hitting spring. Should protrude beyond wheel not more than 0.750". Woody
Old Oct 24, 2010 | 12:20 PM
ModlessG's Avatar
You guys are spot on as always. I did not drive the car perhaps 30' and pulled the wheels off. I measured the stock bolt it goes about 5/16" into the hub. The new wheel bolt goes 10/16" into hub the brake springs are right there. The bolt just barely scared the spring in the hub. the bolts have 1" of thread they should have no more that 3/4". Maybe I got lucky with no damage. Thanks for the help!!!
Old Oct 24, 2010 | 12:28 PM
bmorgan's Avatar
Here is where I have found the best prices on lug bolts. Lug Nuts Wheel Adapters Wheel Spacers Lug Bolts. Hope this helps.
Old Oct 24, 2010 | 02:17 PM
ModlessG's Avatar
I have a feeling that Tire rack is going to overnight me some correct length bolts
Old Oct 24, 2010 | 02:51 PM
bmorgan's Avatar
So, did your parking brake seem fine?
Old Oct 24, 2010 | 05:22 PM
ModlessG's Avatar
I test drove the car this afternoon. No weird noises and the parking brake works seems normal.
Old Oct 24, 2010 | 07:20 PM
Dementors's Avatar
I agree with you Modless. I continue to be impressed how fast these guys diagnose issues.
rmcdaniel12
Sep 26, 2016 05:37 PM
tom2112
Dec 1, 2015 09:02 AM
tom2112
Jul 28, 2015 08:12 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
axnguyen
Jul 21, 2015 11:41 AM
