ECM Change
Old Oct 28, 2010 | 09:25 AM
BLACKSRT-6's Avatar
Default ECM Change
I have a Eurocharged tuned ECU in one SRT-6 and a stock ECU in the other. Both cars are equally equiped with exception of the tune. Can the ECU's they be swapped without any negative effects? Thought i'd ask before I made a mistake. Thanks
Old Oct 28, 2010 | 10:57 AM
apkano's Avatar
Life is random...so am I.
Default Re: ECM Change
To the best of my knowledge....... no they can't.
You'd have to overcome the "security" programming that cause the ECU to look for a matching trans, security module, etc., etc., etc..
Probably the best person to ask is Rudy.
Old Oct 28, 2010 | 11:06 AM
MikeR's Avatar
NO, it can not... if you swap them the car will turn over the first time and then nothing.... I tried it with the SSB and Aero..... the VIN must be programmed into the ECU.... it will not hurt the ECU, you just have to switch them back...
Old Oct 28, 2010 | 12:13 PM
BLACKSRT-6's Avatar
Thank you,
Old Jun 9, 2013 | 08:16 PM
JimmySkullz's Avatar
beckmann technologies unlocks and Programs , also contact Rudy Compart on this site, he may be able to help.
Valk
Jun 22, 2025 09:15 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
o55ie18
Oct 5, 2015 05:50 PM
nataliefs
Oct 5, 2015 01:03 PM
