Brakes >>> question?
Old Jan 10, 2011 | 05:41 PM
freakingfastsrt6's Avatar
Default Brakes >>> question?
Im doing the Brakes for the first time and have stumbled unto a problem...I have taken off the 2 hexbolts on the back of the caliper, and can't seem to get the darn caliper off, These things are just stuck on there is there somthing else that is holding them in place? I've done a search and have come across lots of N/a's with what looks as they may have a different set up??? I seeing there may be a hex on the back of the pins that may need to be taken off? Also removing the front rotor? Im not able to pry off the cap? Is there another trick or somthing that im missing?
any help would be great...
thanks
Old Jan 11, 2011 | 12:08 AM
Default Re: Brakes >>> question?
thanks
I'm not too sure what you mean, have you looked at the Service Manual. If not it's here, https://www.crossfireforum.org/forum...tml#post111722 download it and read it at leisure.
Old Jan 11, 2011 | 06:47 PM
32krazy!'s Avatar
the hex bolts hold the carrier in place. put them back in. look for 2 plastic plugs on the back of the caliper. remove them and theres 2 torx bolts inside. remove them and the caliper will slide out of the carrier
PNA
Aug 30, 2024 02:06 PM
xfireohio
Jul 20, 2020 12:03 AM
ayebb
Sep 18, 2015 03:35 PM
davidc90
Sep 6, 2015 10:37 PM
RedNeck
Sep 4, 2015 09:54 PM
