AC advice needed
Old Jun 15, 2011 | 12:44 PM
blackpepper's Avatar
Default AC advice needed
My AC get about half a can low after 2 days.Walmart has a sealer kit for 23$ and the dealership charges 120$ to find the leak.That sealer kit sound good but I dont it
Old Jun 15, 2011 | 12:49 PM
maxcichon's Avatar
Default Re: AC advice needed
Mine was dead-dead-dead last summer. Leaking Schraeder valve. Check there first?
Old Jun 15, 2011 | 06:30 PM
I will check that first because the system on leaks out about half a can after 2 days.
Old Jun 15, 2011 | 06:43 PM
magredvet's Avatar
Mine was the same, turns out it was a leak in one of the metal pipes from the condensor. I tried the sealer, and it blocked the expansion valve, so I ended up replacing the pipe, and the condensor, since the pressure built up and blew a hole in it.
I would be extremely cautious with the sealer, I've never had success with it.
if you find an independant shop they'll find the leak for you, and I'm sure it will be cheaper than Chrysler.
My repair ended up at about $1400, the pipe is expensive, used an aftermarket condensor, and even the oil in the system is not 'normal' and guess what .......expensive
Old Jun 16, 2011 | 08:14 PM
Thanks I will stay away from the sealer taking my car to the shop next week.
Old Jun 16, 2011 | 08:23 PM
waldig's Avatar
Talking Re: AC advice needed
We started using the auto sealer in our vans and it worked fine. Most leaks are at the O rings on the lines or the carbon to carbon compressor seal. I would suggest the leak stop but you can do a leak check on all the joints with soapy water solutition. Also look for oil stains on joints.
Dealers are typically scortched earth pricing and Id never go to them, keep looking for solutitions, Enjoy. Woody
Old Jun 16, 2011 | 08:51 PM
arado's Avatar
Spent my life in the HVAC business. Take the car to a quality shop for repair. It takes skilled labor to repair. I did a lot of it for family and friends. they still call. gary
Old Jun 17, 2011 | 04:32 PM
My valve is leaking also dealership trying to sell me a 300$ hose saying they can't order a valve by itself.
Old Jun 17, 2011 | 05:41 PM
waldig's Avatar
What does valve mean, ?? which one?? Woody
Old Jun 17, 2011 | 06:57 PM
The one you add freon thru looks like a valve stem from a tire.
Old Jun 17, 2011 | 07:06 PM
waldig's Avatar
Leaks there are not important, there are caps for this fitting that are gas tight. Woody Not plastic ones.
Old Jun 18, 2011 | 09:32 AM
magredvet's Avatar
You can also replace the schraeder valve. There's a special tool to remove it without losing refrifgerant and opening the system to the atmosphere. It costs about $100, but still cheaper than the pipe.
Typically our valve is an odd size, so the one you buy for 'most' vehicles doesn't fit.
Let me know if you need more details, on the tool or valve core
What part of the country are you in ?
If you're close to Houston you can borrow mine, or maybe someone near you has one ?
chturner
Dec 13, 2015 08:17 PM
crossfiren00b
U.K.
Aug 18, 2015 01:58 PM
Trenzman
Jul 24, 2015 10:12 PM
RED DOG
Jul 22, 2015 08:55 AM
Rus921
Jul 20, 2015 11:09 AM
