Help :) ?
Old Jan 7, 2012 | 09:51 AM
FUBU's Avatar
Default Help :) ?
Trying to install the new sc pulley. But I am stuck at step 2 (downloaded the EC document) it says that I should turn the tensioner counter clockwise. There are a 15mm and a smaller 9mm nut. How do I do this?!?
Old Jan 7, 2012 | 09:55 AM
FUBU's Avatar
Default Re: Help :)?
I did it. I got it. Just take a 15mm socket and pull it towards you to relieve tension so belt can be taken off. Ok I am Swedish.
Old Jan 7, 2012 | 11:59 AM
ModlessG's Avatar
Forge ahead.Let us know how it goes
Old Jan 7, 2012 | 12:03 PM
32krazy!'s Avatar
now look at the tensioner again. theres a nut on the center of the pulley and the shaft that the nut is installed on has a torx shape at the end of it. thats what you use to apply pressure to relaease the belt.using the nut will loosen when enough pressure is applied to try to release the belt. use the torx bit
Old Jan 7, 2012 | 12:25 PM
FUBU's Avatar
Forge ahead is a good word. that would have helped me. But I managed to just pull it towards me so all sorted. Everything else went smooth. so now I have the 64,7 mm installed. looks much brighter and shinier aswell ;D My biggest woories are the "screws" that pop up from the pulley. The look like the are about to go into the belt. But no strange noise nor wobbeling. Will send you a video in a bit.
Old Jan 7, 2012 | 01:41 PM
FUBU's Avatar
http://www.youtube.com/watch?v=fMS3WR7PBTk
Does it look alright?
Old Jan 7, 2012 | 01:47 PM
32krazy!'s Avatar
video is set to private. cant view it
Old Jan 7, 2012 | 02:04 PM
FUBU's Avatar
Sry mate :d Should be sorted now.
Srt6 with 64.7 mm SC Pulley - YouTube
