Need Diff Parts
Old Feb 29, 2012 | 02:53 PM
Ideating's Avatar
Default Need Diff Parts
Hey guys I just recieved a parts list/ Estimate from my mechanic for a Rear Dif rebuild. I got most of the diff intirnals from Woody this past weekend (thanks Woody). Now that the mechanic has taken the rear out, I feel like there trying to take me for a ride.
Basicly I need to save some money were ever I can. If you have spare parts or know where I can find any of these parts send me a PM
Ring and Pinion Gear Set $375.18
Main pinion Bearing $140
Bearing (2) $216 part # 52111478AB
Gear Oil (2.5) $124.97
Pinion ring $8.70
Pinion Shim (2) $12.99
Carrier Shim (2) $7.00
Pinion Spacer $21.20
Pinion Bearing $49.99
Pinion Seal $15.35
Axel Seal (2) $15.70
Mopar LSD Additive $19.99
Parts Cleaner $4.99
Not to mention they want $170.63 to Remove Differental inspect fluing and internals
$739.38 for "R&R" Differential
and $682.50 to "Build Differential"
Old Feb 29, 2012 | 02:58 PM
grip grip's Avatar
Default Re: Need Diff Parts
Have you inquired about buying a complete carrier from MrMopar?
Pinion ring $8.70
Pinion Seal $15.35
Parts Cleaner $4.99
Old Feb 29, 2012 | 03:12 PM
grip grip's Avatar
You could also go this route:
2005
Carrier
Chrysler Crossfire SRT,AOD, B36237
A UJ0010
$450
Kubis Auto Parts, Inc.
USA-NY(Auburn)
1-800-233-3799
2006
Carrier
Chrysler Crossfire [440-01431]
00009098
$500
Parts for Less USA-AZ(Tucson)
1-800-571-7899
Old Feb 29, 2012 | 03:56 PM
Ideating's Avatar
How do i get in touch with MrMopar?
is it safe to assume the carrier would contain the major parts...
Old Feb 29, 2012 | 04:00 PM
grip grip's Avatar
The carrier will be the entire housing with everything inside. This would be a simple swap and require only basic mechanical skills to perform.
Go on ebay and search "crossfire carrier" and you'll see what I mean.
Just send a PM to "MrMopar".
Old Feb 29, 2012 | 04:16 PM
waldig's Avatar
Talking Re: Need Diff Parts
LSD additive is interesting as the rear is an "open" design and has no LSD capacity. Labor is a bit on the high side. Woody
Old Mar 1, 2012 | 01:44 AM
Buggin's Avatar
Wow, they are building almost a complete new rear from scratch based on that list... Some of those prices are WAY high and some low (like the ring/pinion). You can verify all the prices here:
2002 MERCEDES-BENZ SLK32 AMG Parts - OE Discount Parts
And their labor rate is steep, IMO.
Old Mar 1, 2012 | 02:17 AM
As mentioned before:
Personally I would purchase a used entire housing, prefer low mileage if you can. Simple change-out for a shop w/hoist. Another $20 to drain and refill gear lube. Then alignment.
Old Mar 1, 2012 | 03:44 PM
ProjectMayhem's Avatar
I think i paid a little over $600 for a rebuild from some aftermarket company and install at the stealership, Went to 3 different ones before i got a resonable price
Mackel
Aug 28, 2015 06:11 PM
Helot
Aug 15, 2015 04:19 PM
Selbyl
Jul 30, 2015 09:09 AM
55chevy
Jul 27, 2015 08:02 PM
SuperD500
Jul 23, 2015 02:53 PM
