Water Leaks
i just went thru the water leaks PROBLEM... i had about 4'' to 5'' water witch was high enough to soak the elect. parts in that area ..i was lucky and found a used elect.unit to install but repairs of leaks and all was still around $1,200.00 ... the dodge dealer that fixed the leaks told me if they get a recall for the leaks they will refund me and all others ...this is happing to a lot of cars and if we all complain to CHRYSLER maybe a recall is possible....the srt-6 should not have that Meany leaks something was not done right when they put them together,poor materials or ???......... INPUT PLEASE?
Re: Water Leaks
Re: Water Leaks
well, now that the weather is breaking for the good, I quess I had better add this to the "to do" list...
Re: Water Leaks
The following pictures show the water marks where water has got past the seal. Once past the seal the water can start to cause damage. Grip Grips photo shows a poorly placed seal from the factory. In neither photo should there be water stains on the bottom flat shelf, as the seal is closer to the Chrysler emblem.
My car. https://www.crossfireforum.org/galle...m/DSC_0064.JPG Photo by Grip Grip. https://www.crossfireforum.org/galle...18-36_7371.jpg Photo by fastfunfor2 https://www.crossfireforum.org/galle...t_copy-721.jpg |
Re: Water Leaks
THANK YOU ALL FOR THE INPUT I HAD A FEELING IT IS A UP HILL BATTLE BUT YOU NEVER KNOW FOR SURE UNLESS YOU TRY.....so i thought i would throw it out there and see what others thought....
Re: Water Leaks
A brother Crossfire owner came over today with a few issues with his car. To change out the center brake light on a roadster, you must remove the wing and mounting panel. The light is actually sandwiched between the deck lid and the mounting plate for the wing.
First off, only 2 o-rings were found on the 4 studs. You can see the plate had some leakage all the way around. The original seal was not pressed very tight. After we cleaned everything up, we resealed the perimeter area with a double strip of rope chalk. Also placed a layer under wing stand-offs. Coated all metal areas with some antiseize compound. This something everyone should get checked out, whether SRT or NA. James https://www.crossfireforum.org/galle...ium/jim021.jpg https://www.crossfireforum.org/galle...ium/jim012.jpg https://www.crossfireforum.org/galle...dium/jim03.jpg https://www.crossfireforum.org/galle...dium/jim04.jpg |
Re: Water Leaks
First off, only 2 o-rings were found on the 4 studs. You can see the plate had some leakage all the way around. The original seal was not pressed very tight. After we cleaned everything up, we resealed the perimeter area with a double strip of rope chalk. Also placed a layer under wing stand-offs. Coated all metal areas with some antiseize compound. This something everyone should get checked out, whether SRT or NA. James I suspect that water leaks past the top part of the seal and can then get to the bottom and drain out past the ill fitting seal at the bottom. Mine only leaked inside when an ice storm blocked the bottom and the water backed up and went down the hatch latch. There was no sign of water having been in the trunk before. Luckily there was not a lot of water but it had made it way to the bulkhead area and gone down to the first step of the well. Water sits in the flat area behind the wing logo with no slope to exit down. The top part of the seal should be sloped to enable the water to escape to each side. My comments are applicable to the coupe, but in general can apply to the roadster. |
