Crossfire will not start, alarm going off.
Old Feb 15, 2013 | 12:02 PM
petez Racing's Avatar
Default Crossfire will not start, alarm going off.
Hey there,
Drove Crossfire to store yesterday. When I came out the remote for the alarm did not work. I put the key in the door then opened it to the sound of the alarm. Put the key in the ignition and that did not help the alarm was still going off. Car would not start.
Towed to my friend’s Mercedes shop.
A bit later he informed me the PSE pump was bad, no idea I even had one?
PSE pump also know as the Door Vacuum Pump, located in the trunk.
Part #1708000848
Here is a picture and more information on that part.
<http://www.benzworld.org/forums/r170-slk-class/1600468-pse-help-needed-1708000548-compatible-1708000848-a.html>
Does not seem too expensive or difficult to replace.
Hope this helps someone.
Cheers
Pete
Old Feb 15, 2013 | 01:38 PM
RL67037's Avatar
Default Re: Crossfire will not start, alarm going off.
Might be a good time to address the (possible) water leaking into the trunk area if you haven't already. Might save you from having this happen again and getting stranded ... again.
Thanks for posting up the part number and a pic of it.
RL
Old Feb 15, 2013 | 01:56 PM
grip grip's Avatar
Time to pull off the spoiler, clean the area, and reinstall.
Old Feb 15, 2013 | 08:37 PM
stryfox's Avatar
Definitely look for signs of a water leak. When it gets wet it can do exactly that.
If the first one went bad from water the new one will too if it was from water.
BEATv1
Jul 16, 2015 09:40 AM
autumnmass
Jul 2, 2015 10:35 PM
MJPowers
Jun 8, 2015 02:34 AM
gobraves423
Jun 6, 2015 07:03 PM
texex91
Nov 20, 2003 06:00 PM
