CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Crossfire SRT6 (https://www.crossfireforum.org/forum/crossfire-srt6/)
-   -   HELP ASAP I'M STRANDED!!! My car stalled (https://www.crossfireforum.org/forum/crossfire-srt6/60863-help-asap-im-stranded-my-car-stalled.html)
MissSilky Apr 9, 2013 07:26 PM
I was driving my car from Florida to arizona and I'm stranded in San Antonio of I10 West. All of the sudden my car is hard to start it turns over fine but won't start till several tries and now just stalled while idling with brake held down in drive at a light. It only has 67,000 miles on it , I just got it back in October. I only use premium gas and I just took it before I left to get the oil changed and I also replaced the fuel filter ( I used the correct oil we checked it twice) help me!!! Any suggestions?
IBLUBYU Apr 9, 2013 07:40 PM
Re: HELP ASAP IM STRANDED!!!! My car stalled
Crankshaft position sensor ...... have a Mercedes mechanic put it in. If you can find an independent shop. This is pretty common on this platform
DBidault Apr 9, 2013 07:46 PM
It could be the Relay Control Module (RCM) too. I'm here in San Antonio, if you PM me I'll try to help out.
MissSilky Apr 9, 2013 07:56 PM
I just pmd you any help is much appreciated!!!! My car keeps stalling everytime I stop for gas
How much does this cost?
DBidault Apr 9, 2013 08:23 PM
I didn't get your message, check your private messages I just sent you one.
Osofast2 Apr 9, 2013 08:36 PM
At the most about 100.00
pizzaguy Apr 9, 2013 08:58 PM
GET A BOSCH CPS if you buy a generic one, it can waste your time! We've seen this before.
You MIGHT consider a new battery, too. Probably is the CPS but bad batteries or corroded terminals have causes some problems with the engine running right.
ALSO, re-soldering of the Relay Control board is not a bad idea, either.
IN order of likely-hood: CPS, Relay Board, Battery
Do you have a check engine light on? If so, reading the code may tell us all we need to know.
Bill F Apr 9, 2013 08:59 PM
Hey DBidault hope you can help out MissSilky. I see you've been a member since Oct. 2012. Haven't seen you at any of the GTGs or Cruise-ins. You are invited to join us any time.
Mrmiata Apr 9, 2013 09:12 PM
Bosch is the best.. But mine from Advanced Auto is actually doing quite well, if you can't find the Bosch readily .. about 65 bucks...
The Beep Apr 9, 2013 09:28 PM
Good thing you made it to SA as opposed to someplace like Flatonia.
There's a lot of realestate along I10. Hope you're up and running soon.
DBidault Apr 9, 2013 09:34 PM
Hey Bill, I've wanted to get to some of the GTG's but I've been super busy since I joined here. I'll make it to one of the GTG's soon! I bought my car in Universal City back in Oct. I still have some things to do to make it a daily driver though!
I talked to MissSilky and her Dad. Engine cranks strong, no check engine light, and most of the time it stays running once it starts. That sounds like it could be an intermittent connection on something to me. They want to keep pushing ahead and I think they were driving while I was talking to them, I hope they make it okay.
Those of you that have had the bad CPS, did you get an OBD code set when it failed? and was it intermittent or a solid failure?
Doug
Mrmiata Apr 9, 2013 09:40 PM
Seems 9.5 out of 10 throw the code. Mine fired twice after initial failure, and then croaked. I'm wondering about "new fuel" filter.. hope is was the OEM quality and not Auto Zone or equivalent ...
InfernoRedXfire Apr 9, 2013 09:55 PM
There's a lot of open territory between W. TX and AZ with little help. I hope they make it OK.
DBidault Apr 9, 2013 10:05 PM
I didn't suspect the fuel filter at this point but I wouldn't rule it out since it was changed recently. My experience with bad (plugged) fuel filters is a lack of power and stumbling but not a no start issue.
Mrmiata Apr 9, 2013 10:08 PM
It's also the pressure regulator..;)
DBidault Apr 9, 2013 10:10 PM
I did mention that past Kerrville it's a long way to El Paso.
DBidault Apr 9, 2013 10:11 PM
good point, I do remember reading that somewhere!
meh03 Apr 9, 2013 10:36 PM
Doug
My car started many times after the CPS first failed. It is very easy to change and any decent mechanic can change it in 15 minutes. I actually just ordered a spare one I will keep in the trunk in case I ever need to change it out on the side of the road. Just try to get the Bosch brand if you can. Like someone said, there is a LOT of nothing in west Texas and beyond.
meh03 Apr 9, 2013 10:38 PM
You can also search the forum for CPS Replacement if you want to try and replace it yourself.
© 2026 MH Sub I, LLC dba Internet Brands
