Spray mist on front Heat exchanger...
Old May 9, 2013 | 05:58 PM
Billy22Bob's Avatar
Default Spray mist on front Heat exchanger...
One of the guys over at the 230 forum has had his spray mist setup on his working for probably the best part of a year now. Swears by it.
He's just posted some video.
(...click here...)
Gotta keep in mind though that the 230 is an air/air cooler seeing the full brunt of the heat of compression ..ie: upwards of 180F. So the dT compared to ambient is quite high (maybe +100F).
In our case where the cooling water temps are lower and the dT compared to ambient (maybe +50F) not as high - is mist cooling an option?
Just wondering if anyone has one installed?
Old May 29, 2013 | 09:20 AM
srtmodder's Avatar
Default Re: Spray mist on front Heat exchanger...
Hmmm never thought about the difference between the water to air and air to air... First off which one supposedly works better just tryin to increase my knowledge. Second, I wanna give it a shot some time! Hell in Texas any extra cooling is nice! What's the cost on ne of those systems?
Old May 29, 2013 | 02:51 PM
Billy22Bob's Avatar
Subby's the man over at the SLK bbs.
He's running his roots blower up from the stock 0.5bar to 1bar through a port and polish of this SC and machined smaller pulley.
Here's a link to his full thread.
On page 2 it mentions $80...but that's a couple of years ago.
Intercooler Spray testing.... - Page 2 - Benzworld.org - Mercedes-Benz Discussion Forum
It uses the window wash water bottle (about 6-6.5L/Qrts) as the reservoir which laos has your stock indicator light to tell you when it's nearing empty.
It would be much like the evaporative coolers you see in the ceilings of shops etc. in inland areas.
The evaporation of water (2,252kJ/kg) takes 8 times the energy away than it takes to heat water from 86F(30C) to 212F(100C) (300kJ/kg) or for that matter the energy required to melt ice (334kJ/kg)
Now since our HX (behind bumper) shouldnt get above 140F(60C), you wont be boiling water on it, but that is also the case for the A/A coolers used in the high boost SLK230's which get to maybe 180F(82C) at the HX inlet. The water mist still evaporates, taking the heat away with it.
An example calc would be - if you're under race conditions, and it takes you half an hour to use the 6L of water - wack in a drip/waste factor of say 50% and that's about 3.8kW (12,500BTU's) of additional cooling (or about 18F(10C) drop in IAT at WOT)
Putting that into context - it's just south of what a supercooler upgrade is worth for heat rejection.
PNA
Nov 12, 2020 04:44 PM
xfireohio
Jul 20, 2020 12:03 AM
glover
U.K.
Aug 24, 2015 08:03 AM
glover
Aug 23, 2015 05:07 PM
Seawolf
Jul 12, 2015 06:20 PM
