Steering setup/alignment SLK32...going in for a tune...
Old Aug 8, 2013 | 06:11 PM
Billy22Bob's Avatar
Default Steering setup/alignment SLK32...going in for a tune...
I've got a bit of left side drift and gotta get it fixed - been like it since day dot (12 months)
Car's stock with stock 17's and I like to sport and not too worried about tire wear (5k miles a year).
Is it best to go with the factory camber/toe or is there something better...?
Possibly going in 2morrow AM so recommended +/- numbers appreciated.
b22b
Old Aug 9, 2013 | 10:43 AM
boostmonkey's Avatar
Default Re: Steering setup/alignment SLK32...going in for a tune...
The stock alignment specs are pretty decent.
When I checked my alignment, I found the camber to be at -1.3* all around. Great! I installed the MikeR adjustable rear camber arms and adjusted it down to -0.5* rear camber for better straight-line launches. The cornering is still great, and maybe even a little more neutral.
I like very little toe-in. From memory I think I set it at 0.07* front and 0.21* rear toe-in. On the front you want as close to 0* as you can get for good steering response. You don't want any toe-out though or you will won't be happy with the tire wear or straight-ahead tracking.
I played around with the rear toe quite bit. I had rear toe-out on one test drive. What a hoot! The car would rotate like crazy! Not safe for normal driving though. 0.0* rear toe handled well, but the rear wanted to squirm around under WOT acceleration. A little toe-in on the rear, about 0.21*, stabilized the acceleration and has been working great.
Your mileage may vary.
deerhunter
Jan 16, 2021 10:56 AM
cdcrone123
Sep 20, 2015 10:02 PM
bbsrt6
Sep 19, 2015 11:21 AM
princepenson
Jul 29, 2015 07:44 AM
Blackout317
Jul 7, 2015 08:38 PM
