Aem fuel pressure regulator
Question what should aem fuel pressure regulator be set at for proper afr. I just received ecu back from jerry. I added 550cc fuel injectors. Thanks
List of mods.
62 karman
Tweaked mani
DCAI x stream filters
Pheonic spacers
Super cooler
55 fuel pump
Aem regular
IC rudys
Oil can
Needswings lower Y pipe
Iridium plugs
Muffler eliminator
List of mods.
62 karman
Tweaked mani
Pheonic spacers
Super cooler
55 fuel pump
Aem regular
IC rudys
Oil can
Iridium plugs
Muffler eliminator
List of mods.
62 karman
Tweaked mani
Pheonic spacers
Super cooler
55 fuel pump
Aem regular
IC rudys
Oil can
Iridium plugs
Muffler eliminator
List of mods.
62 karman
Tweaked mani
Pheonic spacers
Super cooler
55 fuel pump
Aem regular
IC rudys
Oil can
Iridium plugs
Muffler eliminator
Your list of mods is awesome and you're flying pretty good now I'm sure; and I'm hoping you have an AFR monitor/gauge (at a minimum) to really see what's going on with your engine, since we're all just a little different. Plus or Minus so to speak.
I'm getting ready to install my new sl65 fuel pump this weekend and will soon be upgrading from 65mm to the 62mm Karmen pulley. I'll be purchasing the AEM regulator kit and filter from Rob, so the info. on this thread will be a good starting point as to where to start with the pressure adjustment.
Yes, I've been following that too. Did you get yours from Rudy's group buy? If you don't have it already, good piece of mind is LM21's pulley scatter shield.
Injector 1 wire (one of the ECU connectors) into Innovate SSI4 into Dashdaq.
Here we go again.......and he loves being called Ruby !
Whoops! I didn't mean to open up old news, sorry bout that.
