BAS/ESP dash indicator
Old Mar 27, 2015 | 12:43 PM
rip it's Avatar
Question BAS/ESP dash indicator
My indicator comes on intermittently. Seems to happen more often when driving in the rain. I am driving normal not spinning tires or driving fast. It resets when the ignition is turned off/on.
Any suggestions would be appreciated.
Old Mar 27, 2015 | 02:10 PM
Goldwing's Avatar
Default Re: BAS/ESP dash indicator
Does it come on and stay on? That is strange. I would expect it to come on occasionally in the rain if a tire slips -- it should blink a few times as it works and then go out.
Old Mar 27, 2015 | 04:06 PM
AlG's Avatar
AlG
That would be the traction control light that comes on when a tire slips. I'm thinking a wheel speed sensor is going bad.
Old Mar 27, 2015 | 07:31 PM
rip it's Avatar
When it comes on it stays on until ignition reset. Would I have a code set when the light is on?
Old Mar 27, 2015 | 07:37 PM
I am a little confused, as I am getting old, but bas/esp doesn't usually act that way. Did you do the reset, lock to lock with the steering wheel? I have only had this happen once that I remember, after a dead battery... did the reset, have never seen it again...
Old Jul 18, 2015 | 03:03 PM
rip it's Avatar
Thumbs up Re: BAS/ESP dash indicator
Stopped at a red light and when it turned green I realized the engine had turned off. It would crank but not start. Pushed the car off to a side road and looked under the hood, couple minutes later it started with the check engine light on. Drove it home and parked it. Connected my code reader and got P0 335, crank shaft position sensor. Replaced the sensor and all is well including the BAS/ESP indicator stays off now. FYI
Old Jul 19, 2015 | 05:08 AM
Sweet2002's Avatar
Thanks for posting the finish/completion of the problem. Too many just never give the final result. Doc, made me smile with "confused, as I am getting old". I thought it was my medication. Good to know I'm not the only one
eikon
Sep 9, 2019 10:16 PM
smokey847
Nov 12, 2015 11:54 PM
amx1397
Oct 2, 2015 05:20 PM
JEFASOLD
Sep 28, 2015 12:10 PM
cppeabody
Sep 15, 2015 08:43 AM
