Remove the power steering pump SRT-6, DIY hints needed
Hi everyone,
I am removing the power steering pump on the srt-6 and it is being a pain in the bottocks.
Have anyone ever done this?
1. belt is off - done
2. oil in reservoir has been sucked out - done
3. supply line from reservoir is off - done
4. remove the return hose from the power steering pump
here things gets tricky - Which is the return hose?
5. remove high pressure hose from power steering pump - done
Difficult part / or badly described in manual:
6. remove the power steering pump by removing two bolts attaching it to the engine block
Ok, I have removed them marked in blue. the bolts in red are not even mentioned, but drawn on the diagramme. see below. I managed to remove two of them, on at the top, and another one that is connected to a small pipe, looking like a small cricket club. I believe 1 bolt is the only thing left but it is impossible to reach...
Any ideas ?
Many thanks for help...
Any ideas ?
I have made it
Will make a DIY.
Diagramme is from SRT-6 manual... go figure.
Will make a DIY.
rayth
41
Jul 31, 2019 04:02 PM
