complete rear diff.
Old Sep 15, 2015 | 11:19 AM
pop49's Avatar
Default complete rear diff.
Hi Guys and Gals, Is it still possible to get a new diff for the SRT6 in the US. Here in Australia they want ridiculous amounts which equates to basically scrapping the whole car. Im over trying to get mine repaired as it has been close to 5 months in the shop on 3 occasions. They cant seem to get it right it either leaks oil and still makes a whining noise anything over 55mph. thoughts please as it is still under warranty.
Old Sep 15, 2015 | 11:27 AM
stryfox's Avatar
Default Re: complete rear diff.
I put a used one in mine I got off a forum member when I broke mine.
There are guys here that have put the one from the standard crossfire in. The only difference is the ratio not the strength of it.
You will need to have the computer programmed to it works. There is info on it here. Try searching.
Old Sep 15, 2015 | 11:42 AM
Speedy4x4's Avatar
Default
A 3.07 vs a 3.27 ratio
Old Sep 15, 2015 | 01:40 PM
pioneer4x4's Avatar
With the low gear with my 6sp, I'd prefer a 3.07 in mine. Getting the car programmed to the right ratio would be my issue.
Old Sep 15, 2015 | 02:48 PM
I can get u a 307 direct bolt in for 500.00 usd + shipping anytime you want it. pm me of send me your Phone # i have a majic jack and can call u,
if you want a 327 gear set ,i have to look but i think i have one ,, diff. 500.00+ tcu 6.99.00 or send me your tcu and I'll tune it for 499.00 jim
Old Sep 15, 2015 | 05:20 PM
AB_SRT6's Avatar
Also consider sending your diff to Wavetrac to have their LSD installed. If your case is good, could be a remedy.
Old Sep 15, 2015 | 05:41 PM
$1250.00 for the wave trac
$250.00 shipping both ways
$350.00 to build your + 175 to 250 for new bearings/parts.
Old Sep 15, 2015 | 07:36 PM
Speedy4x4's Avatar
Default
If your car is a NA 6 spd. I have been told you do not need to reprogram, only for automatics.
Old Sep 17, 2015 | 06:17 AM
pop49's Avatar
Thank you gents fro your replies, at the moment the car dealer has it back and under law he has to fi it or...dare i say give me my money back( which i dont want as the SRT6 in Aust is like rocking horse etc.) In aust they want 15800 for a new diff which is madness. I may well end up buying a diff from the US and getting a wavetrac put in as you guys seem to actually know what you are doing. I have been given a Kia cerato to run around in for now and it goes to redline a lot lol. Nothing like the crossy. there is another in melb (3400 kms away for 25K aust ) but its black, may end up flying ove rand getting that one instead but i really like the SSB. Are new diffs still available in the US?
Old Sep 17, 2015 | 08:30 AM
pioneer4x4's Avatar
I would assume something needs done for the speedo to work right, or does run off of something other than trans/driveshaft RPM like ABS sensors? Never know with the Germans, like the VWs running it off the front wheel bearing caps.
Old Sep 17, 2015 | 05:23 PM
Thank you gents fro your replies, at the moment the car dealer has it back and under law he has to fi it or...dare i say give me my money back( which i dont want as the SRT6 in Aust is like rocking horse etc.) In aust they want 15800 for a new diff which is madness. I may well end up buying a diff from the US and getting a wavetrac put in as you guys seem to actually know what you are doing. I have been given a Kia cerato to run around in for now and it goes to redline a lot lol. Nothing like the crossy. there is another in melb (3400 kms away for 25K aust ) but its black, may end up flying over and getting that one instead but i really like the SSB. Are new diffs still available in the US?
I am looking for a spare diff myself. So if I run across one, I will let you know. I can put together the whole set up if you like...wavetrac, diff and all just like Jim stated. Would just need to find out the cost of shipping something that heavy that far...
Old Sep 17, 2015 | 10:25 PM
Padgett's Avatar
I'd like a 2.67-2.73 rear axle, might make 1st usable other than for malls.
Old Sep 17, 2015 | 11:47 PM
Not only could this be done ,,you could drive down south,,we change the rear , the tcu and u drive home. that same day.
Old Sep 17, 2015 | 11:48 PM
pop49's Avatar
Thanks Doc, would definitely take you up on your offer if you do get one. I love my crossy very much, it would have to be the best car that I have ever owned and gives me a thrill when driving. i like odd ball stuf and have in the shed a can am spyder and a Bimota YB9Sri which are all keepers. thanks again.
Paul.
Old Sep 25, 2015 | 05:38 AM
Sweet2002's Avatar
Off topic but if you have a traction issue get a R compound tire and you will no longer have a traction issue! Something like TOYO PROXES R888's or the venerable Mickey Thompson drag radial, or the Nitto NT-01 or NT-05's. These tires dig and GO! I found my TOYO PROXES difficult to spin no matter how hard I tried. Just a thought. Mark
Old Sep 28, 2015 | 03:50 PM
ichon's Avatar
I have a used rear differential (less than 1000 miles) for sale if someone's still looking for one. $525.00 plus s/h.
Old Sep 28, 2015 | 04:10 PM
what car is it out of ,,,srt6 or limited,, or mercedes with a 346 gear set in it? jim
Old Sep 28, 2015 | 07:44 PM
Billy22Bob's Avatar
I have a set of internals removed when I had my wavetrak installed - but you probably need the ring and pinion - where the noise woudl be eminating from ....???.....which are obviously back in my car...although whilst you are looking - a spare ring and pinion would be handy...several reports of failures when you mmod up.
Old Sep 28, 2015 | 11:48 PM
Originally Posted by Billy22Bob
...several reports of failures when you mod up.
not really, I ran the 307 for 2 years (before the tcu mod came along) then ran a 327 for the next 3 years without a failure.
when i did brake a axle it was because i left the traction control on during a burn out,and the gears inside the diff were welded. if you get noise,(a howl ) from your rear it is not set up correctly,, Mercedes use of the snap rings as spacers, and it is one of the worse ways to set up a rear.
all wave trac's are made the same ,yet none of the center sections of our diffs. are the same, so when you build your diff. with a wave-trac you must set the ring to the pinion. or you will get noise, ware. and failure. I have had to cut down snap rings on two of the three diff's i have built. I have 2 sets of snap rings now as spares.
HOW did I do it ?, I used a fly wheel grinding machine and mic then every two turns. jim
Old Sep 30, 2015 | 11:14 AM
ichon's Avatar
Hey Jim, it's out of a N/A...A2203510405
deerhunter
Jan 16, 2021 10:56 AM
xfireohio
Jul 20, 2020 12:03 AM
stlas69
Sep 3, 2015 10:28 AM
AustinGSrider
Aug 29, 2015 04:40 PM
MAXIMUM
Aug 4, 2015 11:04 PM
