Is my alternator dead?
Old Jan 15, 2016 | 05:20 PM
velociabstract's Avatar
Default Re: Is my alternator dead?
It's not the only option. The parts store showed a Bosch ($$$) Valeo ($$x$$) and their Carquest alternator with lifetime warranty. But, the Bosch and Carquest came with the 6 rib pulley. We pulled the 6 rib off and put my 8 rib on but it protruded more than normal. That was enough for me to go for a stock alternator to be sure offset for the serpentine belt was correct.
Les
Old Jan 15, 2016 | 05:53 PM
Dementors's Avatar
Understood. I have found the Valeo from $250 to $850( Mercedes Dealership) for a stock replacement and nobody has it in stock so had to order it. Of course we figure this out after we have the car pulled apart!. Glad this thread was going to catch me up quick.
Old Jan 15, 2016 | 11:48 PM
Post #12 shows the correct pulley, you do not even mention the Chrysler or Mercedes part number. Use the Valeo number only.
The Valeo numbers are in the right hand column of the sheet.
Old Jan 18, 2016 | 12:00 PM
Dementors's Avatar
Is this the correct alternator for the SRT 6? The one that showed up at the auto parts store today is the wrong one so I am ordering it myself, but would like someone to double check me since this seems to be more difficult than I could of imagined! )
Amazon.com: NEW OEM VALEO 120A ALTERNATOR 112-154-02-02 A1121540202 11395 SG12B060 2542572: Automotive Amazon.com: NEW OEM VALEO 120A ALTERNATOR 112-154-02-02 A1121540202 11395 SG12B060 2542572: Automotive
Amazon.com: Valeo 120 Amp Alternator for Mercedes Benz C32 Slk Kompressor Eng 2001-04 SG12B060: Automotive Amazon.com: Valeo 120 Amp Alternator for Mercedes Benz C32 Slk Kompressor Eng 2001-04 SG12B060: Automotive
Thanks
Old Jan 18, 2016 | 12:50 PM
Thanks
The numbers match the bottom one in the pic below (A439420), so yes that is the one.
Eight grooves in the pulley is what you need and it has that as well so you are good to go.
Old Feb 4, 2016 | 01:42 AM
Dementors's Avatar
The alternator arrived and has been installed. All is working as it should. Thanks for the help everyone.
Old Feb 4, 2016 | 06:05 AM
Good to hear.
Les
treyleblanc
Nov 7, 2017 01:18 PM
skeet370
Dec 13, 2015 07:51 AM
xfireruinedmyholiday
Dec 9, 2015 09:49 AM
pioneer4x4
Dec 4, 2015 10:03 AM
leaddog2015
Nov 25, 2015 07:37 AM
