Broke some thing on super charger???
Old Feb 9, 2016 | 04:40 PM
fastfred's Avatar
Default Broke some thing on super charger???
There is a metal pice sticking out of the supper charger and it cut the water line bottom right of picture and cut thru padding on inside of hood any HELP on what has happened please ???
File Type: jpeg
Old Feb 9, 2016 | 04:53 PM
fastfred's Avatar
Default re: Broke some thing on super charger???
Here another pic
File Type: jpeg
Old Feb 9, 2016 | 04:59 PM
chuK_138's Avatar
Broken dogbone spring and cut air pipe. Looks like an aluminum pulley from the corrosion.
Old Feb 9, 2016 | 05:34 PM
fastfred's Avatar
The water house is strait forward but the supper charger
What's the fix any idea??? Thank you
Old Feb 9, 2016 | 05:38 PM
chuK_138's Avatar
You need a new supercharger pulley. It's a 65mm you broke from the looks of the pics. The air pipe is hard to find used. You'll probably need to have someone weld it.
Old Feb 9, 2016 | 07:06 PM
fastfred's Avatar
Anyone have a USED 65 pulley ??
fastfred's Avatar
Where's a good place to buy a new 65 pulley???
Old Feb 9, 2016 | 07:30 PM
chuK_138's Avatar
Eurocharged
Old Feb 9, 2016 | 09:13 PM
fastfred's Avatar
Eurocharged
Well that's the place I bought this 65 from them so they are still the one to buy from and I think I'll tell them this one failed.......
Old Feb 9, 2016 | 09:20 PM
fastfred's Avatar
Does anyone have a idea why this fails???
Old Feb 9, 2016 | 09:56 PM
chuK_138's Avatar
You may want to invest in a latemodel21 scatter shield for the next one, regardless of which SC pulley you choose.
Old Feb 10, 2016 | 09:42 AM
SRT6 T15's Avatar
https://www.crossfireforum.org/forum...-c-pulley.html
Old Feb 10, 2016 | 10:45 AM
Yes. ..............
I would not use one if it was given to me.
It makes you go fast but the risks are too great for me. More will fail as time goes by. Heck, even the OEM ones will fail eventually, these after market ones will fail and have failed much sooner.
If you insist on using one, do as advised previously and fit the LM21 scatter shield. I would advise anyone using an after market pulley to use the scatter shield.
The dog bone spring should be made from a steel alloy that has been heat treated so that it is in fact a spring. Many springs are colored by this process, most often blue. I doubt your one is a real spring and is probably just stainless steel.
Stainless steels do not make the best springs. The OEM ones are springs and are not blue, they are probably treated against rust.
Only pulleys where the clutch plate returns to the stops when the magnet is switched off have real springs, the rest will fail in a short time.
Old Feb 10, 2016 | 11:17 AM
4drturbo's Avatar
"If it is aluminum then it will fail for sure as aluminum cannot take the strain of the belt over the areas not supported by the bearing, it gets brittle due to these stresses and breaks." -onehundred80 There is a lot of info about why they fail all over the forum. But then again, there are members who have good luck with them. It was mainly their 62mm pulley failing due to the size, so now EC's 62mm is made in steel. I still don't understand why they don't make their 65mm in steel. They never responded to me on why. I played it safe and just ordered this one:
https://www.crossfireforum.org/forum...2-c32-amg.html
Email him. He takes $400 including PP fee's. It gets shipped from Poland. Make sure you get the steel one. He offers them in aluminum or steel.
Mercedes AMG C32 SLK32 Chrysler Crossfire SRT6 SRT 6 Smaller supercharger Pulley | eBay
^^Here is his eBay link. Its $460 going that route. But if you email him and not go through eBay it is cheaper.
Old Feb 10, 2016 | 12:02 PM
chuK_138's Avatar
I have to agree with onehundred80 on the "spring" you have pictured. That piece of metal looks to be stainless steel with no sign of heat treatment. The guy from Poland advertises his springs are made from a super alloy....okay?!? Yet he doesn't mention anything else about what alloy is used or how they are stronger. I have a problem trusting that, but that's just me. Someone needs to step up to 7 series aluminum or go back to stainless steel so we don't get more posts like these every month. That's four EC 65mm pulleys done in the last month. They may not post about it here on the forum, but four units in a bit over a month seems like something EC should rectify.
Old Feb 10, 2016 | 12:45 PM
This thread is about the dog bones, not the aluminum pulley itself. I have forecast the failure of these pulleys since the early days, I was pooh poohed often. The aluminum cannot take the stress from the rivets, this has been obvious since the Code 3 pulleys appeared. The rivets came loose in those and rattled.
One maker even admitted in so many words that the dog bones in his pulley were not springs and I contended that if they were not springs then they would not last long at all. The set up involved at least two adjustments to the shims because the dog bones would stretch and the clutch plate would not return to the stops. Using more shims puts the pulley more and more out of alignment to the rest of the pulleys.
I think all the springs from the North American ones are just machined from stainless steel. The OEM dog bones are punched from sheet metal, rounded off on the edges, heat treated and surface treated against rust. That is an expensive proposition if you are not making thousands. They are also thinner than the after market springs because the after market springs need the extra thickness to be strong enough.
These pulleys were expected to make money but not enough R and D was done on them, they were made with little thought given to the design. As I said in an earlier post here, if the clutch plate does not return to the stops then the dog bones are not springs and if they are not springs they will fail like the one in post one of this thread.
No matter what the aluminum used it cannot take the stresses imposed by the dog bones as designed now, the rivet will slowly work its way loose and start rattling. If the flange on the pulley was thicker then it might stand a chance, maybe two times the rivet diameter with the use of a good aluminum alloy.
Old Feb 11, 2016 | 05:04 PM
fastfred's Avatar
I held onto my stock setup so I think I'm going to put it back on do I need to change the tune also or can I get by with the upgraded tune with stock pulley?
Old Feb 11, 2016 | 05:33 PM
fastfred's Avatar
Ok im getting it... Never said I was good on working on cars ...
Old Feb 11, 2016 | 05:57 PM
fastfred's Avatar
I called need wings and he walked me thru... He's a real good guy and a lot of help
Old Mar 5, 2016 | 03:47 PM
burnzboy2's Avatar
Default Re: Broke some thing on super charger???
I had this happen to me with the Eurocharged. They sent me a new one at no charge. I then added the Needswings Pulley Saver Kit, because this damaged where the idler pulley mounts (left of supercharger pulley.) I also bought the LateModel21 Scattersheild, so this won't damage everything again. I had my independent Mercedes mechanic replace the pipe and hose. Fun stuff. Here are links to everything I bought after. You're not alone.
Scatter sheild:
Scatter-shield for Supercharger Pulley (SRT-6) Santa Clara - CrossfireMarket
Pulley saver kit:
NeedsWings Performance Products. Pulley Saver Kit Waldig NeedsWings C32
