Eurocharged Stage 1 setup
I am trying to locate some one who has purchased and installed the Stage 1 performance package from Eurocharged? I am thinking this is the best route to take with my 3k budget as it looks like these items are all complimenting each other. Here is the link to the package. Any member that has purchased this please chime in.
Stage 1 Power Package: Crossfire SRT6 - Power Packages - SRT6 - Crossfire - Products
I do not have this package but would advise against the 185 pulley, it really over spins the alternator and water pump. I would not go over the 181 then a smaller SC pulley if you really want some more boost. Cooling is a necessity as is upgraded fuel supply and a tune but you can do all that pretty close to your budget if you shop and look for sales.
I really like my 185. But it's true of over spinning the accessories. If you go with this pulley,then also purchase the pulley saver kit from NeedsWings that will supply you with the pulleys to slow accessories back to normal speed. A MB55 fuel pump upgrade with tune so you want run lean in top of third gear. Then enjoy feeling the power. Squirrel Crusher
[QUOTE=Squirrel Crusher;866975]I really like my 185. But it's true of over spinning the accessories. If you go with this pulley,then also purchase the pulley saver kit from NeedsWings that will supply you with the pulleys to slow accessories back to normal speed. A MB55 fuel pump upgrade with tune so you want run lean in top of third gear. Then enjoy feeling the power. Squirrel Crusher[QUOTE] danielalexander81 if I were you. I would contact Needswings, as his supercooler,,,,181 or 185 pulley and his tune, I think he works with speedriven for a better tune, and i think less money.
I was given the information to a local shop called Sixth Gear Performance which as it seems has some good reviews. I ordered the Stage 1 Eurocharged Kit through them. I will speak with my contact tomorrow about the information you guys are bringing up and see what happens. I am already on the sced for getting Stage 1 installed and paid the deposit. If I need to spend some more money and make sure all components are covered with the extra power then so be it. I would rather spend the money now and make things right then have things fail and blow something up.
[QUOTE=amx1397;866978][QUOTE=Squirrel Crusher;866975]I really like my 185. But it's true of over spinning the accessories. If you go with this pulley,then also purchase the pulley saver kit from NeedsWings that will supply you with the pulleys to slow accessories back to normal speed. A MB55 fuel pump upgrade with tune so you want run lean in top of third gear. Then enjoy feeling the power. Squirrel Crusher
When I got my tune on Rob's recommendation it was with Inmotion located in Oak Grove Oregon.
[QUOTE=JEFASOLD;867017][QUOTE=amx1397;866978]
Jim F , that,s great i here that Inmotion takes a lot of care into his tune,( as to your mods) can't wait to here/ see it run. jim
