Leaking oil out of...
1 Attachment(s)
Xfire finally out of storage after a 5yr hiatus (yikes), and after doing a bunch of maintenance and getting the car smogged (ugh) I noticed I was leakin' a bit of oil out of the block. It's right below the oil fill cap. I sifted through a bunch of "oil leak" posts on the forum, but I didn't see much.
Anyone have an idea what this could be? I have to rip the manifolds back off to install new gaskets and I thought I'd address the problem at the same time. Pic attached. Thanks and glad to be back :) |
Re: Leaking oil out of...
Vent cover re-sealing and possibly lower oil fill gasket.
(Post 884960)
CLICK |
Originally Posted by mjgroves
(Post 884992)
Yep, looks like it. Thanks for the PDF link, got myself a DIY for next weekend.
https://www.amazon.com/Permatex-8218...dp/B0002UEN1U/ :p ;) AND, pay close attention to the torque on those screws. If I am not mistaken, they may need to be replaced. If not, make sure you do not 'overtorque' them (very low setting in the inch pounds). ;) . |
Super helpful and exactly what I needed! Thanks.
I'll make sure to replace the bolts also. After I buy a digital torque wrench. Been wanting one of those anyway. |
(Post 885041)
. The torque setting for the steel screws on the valve covers is 8 N.m = 71 in-lb = 6.0 ft-lb (7 ft-lb in our Service Manual). Source; http://www.benzworld.org/forums/w220...ml#post7941161 See also this. CLICK |
The above link in onehundred80's post is VERY descriptive !
I learned something new, RTV = Room Temperature Vulcanization |
(Post 885070)
