Supercharger Suckage
Old Apr 22, 2017 | 01:14 AM
05roadsterguy's Avatar
Default Supercharger Suckage
Hello boys and girls, some of you may have noticed we added a 6 to the stable last month, so I am looking for some advise from the minds of some great people. But I guess you will have to do.
41,000 miles, and the supercharger is working sporadically. I know it could be the Throttle, or gas pedal, but I think it is the intercooler. Always works from dig, but is 50/50 from rolling start and often just does nothing from 45 + MPH. We have put 600 miles on it since taking ownership, and the performance has been steadily degrading. Occasionally when cruising at 50+ MPH it gets a burst of power, like a surge as if the supercharger just kicked in with no change in throttle input. This has only happened 5 times that I know of, though it is the wives baby. It exhibits most symptoms of a bad IC pump, but I wanted to check in before I order one to replace it.
What say Ye?
Old Apr 22, 2017 | 07:25 AM
robby363's Avatar
Default Re: Supercharger Suckage
It's most likely the pump from the symptoms you described.
Old Apr 22, 2017 | 07:39 AM
RKC00's Avatar
I just went through the same thing. I chased ghost with no results. Replaced the IC Water Pump, now All Is Well.
Old Apr 22, 2017 | 08:03 PM
Yeah, that's where I am leaning too, but I am just working on a consensus. I need to order this weekend.
Old Apr 22, 2017 | 09:31 PM
TheThomaswastaken's Avatar
The stock intercooler pump goes quick on these cars, mine went at 34,000. Intermittent booost is the main symptom. Someone else did a great write up of their issues, somewhere on this forum. They realized it cuts out about every two minutes, as the supercharger gets too warm. Then, the boost comes back once it is cooled, and this cycle repeats. The first time mine lost boost, the car did what you described: sudden boost without me changing pressure on the accelerator and then no boost while pressing the accelerator.
My personal experience with losing boost and solving it by replacing the intercooler pump:
It took about 20 minutes, most of that was getting the plastic out of the front right fender well. I bought the Bosch, I think, pump from needswings. The only specialty tool requires a torx socket, or however you spell that. Then, afterward, I had the same problem...because my system has an aftermarket separator between the intercooler pump lines and the radiator lines. I had to re-establish flow from the main reservoir to the intercooler by opening two shut-off valves attached to the radiator/intercooler lines.
Old Apr 22, 2017 | 10:11 PM
Squirrel Crusher's Avatar
Rob at NeedsWings has the Johnson pump that's got more flow for ya. Squirrel Crusher
Old Apr 23, 2017 | 12:40 PM
AtomicBubbles's Avatar
I just bought an SRT 6 about 2 weeks ago from today and had the same problems you're describing. Basically the discharge air temp was getting about 190-200 degrees after the SC according to my scan-tool. the ECM will look at that and say "heck no turn off that SC" and you'll lose all your power until it goes below 200 degrees then kick back on.. and turn off again.. etc..
Check Fuse 13 FIRST as it's an easy fix if that's blown. (Driver side) Fuse Panel.
This fuse brings power to the pump.
For me it was the pump. Super easy install took me 1 hour to do it properly. Johnson pump worked fine.
After install I drove around.. Smashed it a couple of times while recording IAT It stayed at about 90-100 and at max 115 then dropped back down..
Hope this helps!!
Edit: Here is the pump i got.
Amazon Amazon
Old Apr 23, 2017 | 01:07 PM
Oddly, I am looking at NeedsWings right now and they only advertise the new improved Bosch 010.
Old Apr 23, 2017 | 01:10 PM
Did you have to modify anything to install the Johnson? Anyone know where a link to a DIY for the intercooler replacement is? I have never done one, but everyone says it is easy to do.
Hope this helps!!
Edit: Here is the pump i got. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Apr 23, 2017 | 01:16 PM
No reports of the 010 pump failing but the Johnson has had its problems. I did not think NW sold the Johnson any more.
Old Apr 23, 2017 | 01:44 PM
No modification needed.. The bracket that comes with the Johnson pump is slightly different.. but I tightened it down well enough for my standards.
Here a good tutorial
Old Apr 23, 2017 | 02:11 PM
JEFASOLD's Avatar
For what it's worth, my Johnson did not last more than 6k miles, went back to Bosch 010 and this has been good for the 15kn since and still working!
Old Apr 23, 2017 | 02:37 PM
Rob does keep current with new items on the market. If he's now supplying the Bosch 010 then he must think it's an improvement. I purchased my Johnson pump from Rob over four years ago and never experienced a problem. You want go wrong with either one. Squirrel Crusher
Old Apr 23, 2017 | 04:33 PM
RKC00's Avatar
I researched both and decided on the Bosch 010. It's a direct replacement.
Old Apr 23, 2017 | 04:53 PM
Steve Jr's Avatar
If your "Johnson's" not working, I would definitely try something new...lol. Rob won't steer ya wrong..
Old Apr 24, 2017 | 05:13 AM
king happy's Avatar
No need to guess . buy yourself a $7 obdII reader , blue tooth it to your phone and you will know immediately if it is your iat temps . Having one earlier would have saved me a lot of time and money diagnosing problems .
my high iat's weren't from the pump but the connection that went from the fuse box to the pump . did the always on mod and it worked fine .
have a used Bosch 010 for sale of your interested .
Old Apr 24, 2017 | 06:36 AM
daveesrt6's Avatar
Yes , a bluetooth OBD a smartphone and the Dashcommand app work well and are not expensive.
Old May 5, 2017 | 01:06 AM
So what is the consensus recommendation for an OBDII reader for our cars?
And yes it was the pump. I installed a Bosch 010 and that solved the problem.
Old May 5, 2017 | 11:08 AM
king happy's Avatar
I don't know about consensus because I have only used one . it is an elm327 , they are small and don't stick out far from your obdii , on ebay about $6.
it well show you iat's , rpm , throttle position , short and long term fuel injection correction , boost and a bunch more . I use it with torque pro from the app store ($5)
I thought was I could start with that then buy something else if needed , haven't found a reason to buy anything else to this point .
I do want to buy an afr gauge to add to it .
Old May 5, 2017 | 12:36 PM
NeedsWings's Avatar
the 010 is the new pump of choice, yes your symptoms describe that of a bad oem pump
and congrats on the new ride and welcome to the forum!
show us the rest of the stable
