Crankcase sensor Frozen
Old Jun 5, 2017 | 09:17 AM
a1roadrunner's Avatar
Question Crankcase sensor Frozen
Hello , has anyone experienced the crankcase sensor being stuck in and impossibe to remove. Is it possible to drill it our ??
SRT6 Coupe 2006 Aero Blue
Old Jun 5, 2017 | 09:53 AM
Default Re: Crankcase sensor Frozen
So when you remove the screw you cannot turn it around a little?
You cannot see the screw, you have to feel for it. A #8 Torx head screw I think.
CLICK for a PDF.
Old Jun 5, 2017 | 10:18 AM
Hello and thanks for the reply ,got the screw out and twisted it slighlty ,unclipped connector on top and with a lot of effort managed to get it to come out about 10mm and its solid and wont move now.Soaked with silicone for 3 days still wont budge
Access is difficult and can only think of pusing back in and out again-or heating up the housing or drilling it out or taking out the gear box
Any ideas appreciated
Old Jun 5, 2017 | 01:10 PM
I would not drill it out as possibly a lot of the part will end up inside.
I would soak it and rotate it while very slowly pull it out. This way the part might get the high spots cut off slowly.
Old Jun 5, 2017 | 03:00 PM
philosophico's Avatar
Get some pliers on it, twist, wiggle and pull. It has to come out if you've removed the screw and unclipped it. Nothing else should keep it stuck in there.
This is not an area you want be drilling into.
