my srt is possessed
Old Jul 19, 2017 | 06:58 PM
king happy's Avatar
Default my srt is possessed
was driving home today and all of a sudden car wont shift , stuck in 2nd gear . multiple lights come on the dash and the speedo isn't working . tach works , ac ,stereo work fine.
turned it off and then tried to restart . all light come on in the dash and stay on , starter will not engage . tried multiple times , it worked once and then no more . Any ideas?
Old Jul 19, 2017 | 09:17 PM
kingtj's Avatar
Default Re: my srt is possessed
Have you checked the RCM (relay control module)? So often, the issue where it refuses to crank at all when you turn the key is a bad soldering joint or stuck relay on the RCM board.
Old Jul 20, 2017 | 06:17 AM
99.9% chance it's the conductor plate in the transmission, it has the speed sensor and also causes limp mode.
About a $120 DIY including new fluid and filter, easy if you have access to a lift, otherwise plan on spending a lot of messy time on your back.
Transmission Conductor Plate+Connector+Filter+Gasket KIT for Mercedes Benz 722.6 | eBay
6-Liters Mercedes Automatic Transmission Fluid (MB Spec 236.10) | eBay
Old Jul 20, 2017 | 08:22 AM
Possessed is better than re-possessed, unless it acts like Christine.
I would be looking at the RCM for bad solder joints and/or bad relay contacts. Look for the thread concerning the mystery no start by tighed1.
Old Jul 20, 2017 | 08:45 AM
Yes, BOTH the RCM and transmission conductor plate ......
Old Jul 20, 2017 | 09:48 AM
king happy's Avatar
dj did the rcm about 6 months ago . I have a spare and will swap . there have been multiple posts of people having the same problem but no real good follow up on the fix ( I hate that)
. just checked for codes and there is a p0600.
Old Jul 27, 2017 | 03:44 PM
king happy's Avatar
Found it , it was the rcm . swapped in the spare and it runs great . tried it for 2 days and all good . put the old one back in and wont start .
so i'm going to send it back to dj and have him look at it . got off easy on this one .
