Replace Conductor Plate
Old Sep 16, 2017 | 03:11 PM
RKC00's Avatar
Default Replace Conductor Plate
2005 SRT6, 100k miles. I'm going to service the transmission, I have the kit, install a Shift Kit and replace the Conductor Plate. Some instructions say to replace the "O" rings on the Solenoids. The question is, Should I, and if so, where can I get the "O" rings or can I use o-rings from a general service kit? Also, should I simply replace all the Solenoids? I can get Rebuilt / Re-manufactured for under $100 a set..
I appreciate your Guidance and Wisdom.
Old Sep 16, 2017 | 05:08 PM
S8MS-01904's Avatar
Default Re: Replace Conductor Plate
O-rings from a kit should be fine. Just watch diameter overall and thickness size.
Old Sep 17, 2017 | 12:52 PM
NeedsWings's Avatar
#42 is a filter which the solenoids slip into $0.90 each x2, no o-rings there
Old Sep 18, 2017 | 01:04 AM
Thanks Rob.
