Obdii??
Old Nov 14, 2017 | 10:58 AM
srs244's Avatar
Default Obdii??
can someone please comment on the value of this particular obdII unit:
iCarsoft MBII for Mercedes Benz/Sprinter/Smart Professional Diagnostic Tool Scanner, New Version??
is the the proper one? will it reset codes, etc and cover the majority of the important vehicle function areas?? if there is a better unit for the srt6, please let me know what you suggest. i searched for comments on OBDII units and only got more confused by all the various opinions regarding these units. unfortunately many of the threads were pretty old which didn't help, l would appreciate any suggestions about the best home use unit to get.
thanks,
steve
thanks
Old Nov 15, 2017 | 03:18 PM
srs244's Avatar
Default Re: Obdii??
over sixty views and no one has a suggestion?? i need some help and guidance, please.
Old Nov 15, 2017 | 04:03 PM
Default Re: Obdii??
I'll comment. I have no knowledge of the above mentioned unit, but I can speak for the LAUNCH CRP123 scanner. I am very happy with it, it does all the codes and resets ( including SRS ), does data streaming and is easy to use.
Old Nov 15, 2017 | 05:19 PM
srs244's Avatar
Default Re: Obdii??
thanks for the input and the reply. that was exactly the information i was looking for in the way of an appropriate unit that did most everything needed.
i appreciate your response.
steve
Old Nov 15, 2017 | 05:20 PM
blasco403's Avatar
Default Re: Obdii??
SrS244,
I as well have no experience with the device you refer to.
I use a app/odbII device from blue driver (bluedriver.com), works well for what I need it to do.
- reset and read codes
- freeze frame to capture instantaneous readings
- smog precheck
- Mode 6
The app and device firmware have been upgraded multiple times since I purchased.
TTYL
Ron
Old Nov 15, 2017 | 05:21 PM
srs244's Avatar
Default Re: Obdii??
Originally Posted by blasco403
SrS244,
- smog precheck
- Mode 6
TTYL
Ron
ron, thanks for the input.
steve
Old Nov 15, 2017 | 05:39 PM
Padgett's Avatar
Default Re: Obdii??
I have yet to find anything better than Torque Pro. Problem is that the good ones for a Merc (like Carly Pro for Mercedes) start with the 2005 R171 and do not cover the 2000-2004 SLK320/SLK32AMG which is the Crossfire platform.
Old Nov 15, 2017 | 08:14 PM
srs244's Avatar
Default Re: Obdii??
Good to know so as not to consider it. Thanks
Old Nov 16, 2017 | 08:32 AM
Default Re: Obdii??
In your previous post when you mentioned this scanner you said that it supposedly reset the SRS codes and U Tube videos showed it resetting them, was that on a Crossfire?
Old Nov 16, 2017 | 08:49 AM
Default Re: Obdii??
For proof positive, I boxed it up and sent it to Crystal who has replaced a bag and needs a reset. Haven't heard back from her yet.
Old Nov 16, 2017 | 08:50 AM
Billto's Avatar
Default Re: Obdii??
Nice unit BUT, won't work with an apple computer. How do I know? Been there done that.
Old Nov 16, 2017 | 08:52 AM
Default Re: Obdii??
That should be a good test and good to know.
Old Nov 16, 2017 | 10:27 AM
Shamrock's Avatar
Default Re: Obdii??
I used it to diagnose a passenger door air bag malfunction. It scanned all systems including DRB. Was able to reset Airbag light.
I borrowed the unit and liked it so well, I bought one for Santa to give me for Christmas.
Old Nov 16, 2017 | 11:00 AM
Default Re: Obdii??
You are referencing the LAUNCH CRP123, right ?
Old Nov 16, 2017 | 12:45 PM
Padgett's Avatar
Default Re: Obdii??
OK I give Amazon "LAUNCH CRP123" and get a Whole Bunch (c) of hits (more than 6) all apparently from Launch. Which, if any or all, are we talking about ?
Apparently you need a special scanner (Mercedes ?) to reset airbag faults. So far have failed to find anything under about $400 that can clear airbag faults in all Crossfires.
Old Nov 16, 2017 | 01:03 PM
Shamrock's Avatar
Default Re: Obdii??
No, I was referring to the MBII.
Old Nov 16, 2017 | 01:11 PM
Padgett's Avatar
Default Re: Obdii??
Oh, Icarsoft.
What I need is one device that can interface or send reports to a PC and can handle scans and resets particularly airbag resets on both a '07 Crossfire and an '01 MB SLK320 (same R170 platform) without having to spend $700 on a C4.
Even if they need different chips for each.
Old Nov 16, 2017 | 05:17 PM
Shamrock's Avatar
Default Re: Obdii??
No, I was referring to the ICarsoft MBII.
https://www.ebay.com/itm/iCARSOFT-MB...UAAOSw0oBZwGsZ
Old Nov 16, 2017 | 07:12 PM
Padgett's Avatar
Default Re: Obdii??
and that will work with an '07 Crossfire ? Know there is something different about the airbag (SRS) system from earlier years.
Old Nov 17, 2017 | 10:47 AM
Shamrock's Avatar
Default Re: Obdii??
Don't know. It works on my 2005 SRT Roadster.
