Timing
Old Jun 11, 2018 | 05:28 AM
Morphh's Avatar
Default Timing
can anyone tell me what timing they have at wot, have pulley,intake,tune and use 94 octane, and only see 18 degree timing advance, just curious how
much more timing I can add safely
thanks
Old Jun 11, 2018 | 04:23 PM
blackpepper's Avatar
Default Re: Timing
With my 65mm pulley modded manis,single intake i was seeing 21 degrees inmotion tune,present day added dcai full exhaust large filter isolated coolant system larger heat exchanger walbro pump freeflow filter aem regulator set at 70 psi I see 22 degrees and 24 degrees with 100 octane gas added to 93
Old Jun 11, 2018 | 05:34 PM
Morphh's Avatar
Default Re: Timing
So u have separate tunes for different octane then?
the computer doesn’t adjust for the octane itself?
Old Jun 11, 2018 | 06:43 PM
Default Re: Timing
No i have a new tune by eurocharged when added more modds an went 62mm i normally see 22 to 24 degrees my scan tool and torque app read the small thing,I run a few gallons of 100 octane for safety while dragracing
Old Jun 15, 2018 | 09:31 AM
Default Re: Timing
I seem 22 degrees yesterday 95 hotside an 24 briefly that nite 70 degrees so depends on the tune temps play a part in timing
rock
Apr 17, 2009 07:37 AM
onehundred80
17
Jan 2, 2009 06:37 PM
BlueStorm
Sep 4, 2008 06:54 PM
tjames.bell@gmail.com
Jan 29, 2008 08:27 AM
413MA
Oct 4, 2007 10:29 AM
