Srt6 ASD relay
Old Oct 8, 2018 | 08:46 PM
Peteroses1975's Avatar
Default Srt6 ASD relay
Does the Chrysler Crossfire have a ASD RELAY
Old Oct 8, 2018 | 08:52 PM
Default Re: Srt6 ASD relay
I give up. What is ASD ?
Old Oct 8, 2018 | 08:58 PM
Auto Shut Down, usually a relay
Old Oct 8, 2018 | 09:14 PM
Geez, then in our case that could be the CPS or the RCM
Old Oct 8, 2018 | 09:17 PM
Can you tell me where it's located got the car check that advance and they said that was the code
Old Oct 8, 2018 | 09:24 PM
Car loses power sometime ESP and BAS light comes on then I lose my supercharger
I I replace my throttle body throttle position sensor accelerator crank sensor cam sensor wheel speed sensors rear RCM fuel pump fuel filter air temp sensor intercooler pump
Old Oct 8, 2018 | 09:37 PM
I don't own an SRT, but I thought I read that when the ESP/BAS light comes on, the SC is disengaged automatically. Someone else can confirm or deny.
I repaired my ESP/BAS issue by replacing the brake light switch.
Gook luck, James
Old Oct 8, 2018 | 09:49 PM
I thought when the brake light switch was bad then you would lose your brake lights I never have
Old Oct 8, 2018 | 09:51 PM
The switch(es) do more than operate the brake lights. Check the wiring schematic. IIRCC one switch is NC and one is NO on the assembly.
Old Oct 8, 2018 | 09:57 PM
How hard is it to replace the brake light switch I do fairly well at replacing parts
Cal_Cobra
Jun 18, 2013 11:14 PM
