Re: Expected performance wirh mods
a AFR gauge is a must, when u get it ,u may have to remove your fuel/filter/regulator (all in one)and put in a adjustable fuel regulator don;t forget it will not work with a return line then u can replace your lower crank pulley with a 180 or 178 along with your SC pulley and get about another 40 to 60 HP with the afr guage the best number for the street is 12.3 remember you are only at 12.3 at wot in 3 ,,4,,and 5 gear
Originally Posted by amx1397
(Post 946003)
- AFR gauge w/ boost connector (~ $427) - Adjustable fuel regulator ($260) https://www.needswings.com/needswing...sure-regulator "This is not to be used with the factory fuel filter/regulator." < with? So I guess as a replacement, ofc. - High flow fuel pump ($323) https://www.needswings.com/55-fuel-pump - Upgrade crank pulley (??? from where) - SC pulley upgrade? This is already a 65mm Eurocharged one What is the effect of your bold text: don;t forget it will not work with a return line ? |
Originally Posted by Diamondo25
(Post 945996)
….Do you think the standard is not capable of keeping the wheels straight with so much power on the regular diff?....
:) Maybe I am not following this correctly BUT, the SRT-6 is only available in the auto transmission. I haven't seen anything referencing a drivetrain conversion here. :) . |
(Post 946011)
(Post 945998)
you can get the short term and long term fuel trims from the OBD
They are handy in determining if you are consistently running rich or lean. After a week I removed it again, and there was substantial more oil in it, only on the right side. Pics here: https://photos.app.goo.gl/gzjkmF8Gb72rPum17 |
(Post 946011)
(Post 946012)
> Once you get to where you are HP wise, it's likely that the best mod you could add is a Limited Slip Differential.
:confused: Apples and oranges, you posted a reference mentioning something about a 'manual'. Did your post mean a manual transmission? If not, PLEASE explain what you meant here ( ...Do you think the standard is not capable of keeping the wheels straight with so much power on the regular diff?...). Your post 19 referenced, if you misspoke then OK . :confused: . |
If you mean the words "standard" and "regular", they were both about the same thing: the standard differential on the SRT-6. I can expect that its made for usage with < 300WHP, and if you go higher it starts being unable to keep the wheels from spinning and making the ESP kick in.
(Post 946007)
So:
- AFR gauge w/ boost connector (~ $427) - Adjustable fuel regulator ($260) https://www.needswings.com/needswing...sure-regulator "This is not to be used with the factory fuel filter/regulator." < with? So I guess as a replacement, ofc. - High flow fuel pump ($323) https://www.needswings.com/55-fuel-pump - Upgrade crank pulley (??? from where) - SC pulley upgrade? This is already a 65mm Eurocharged one What is the effect of your bold text: don;t forget it will not work with a return line ? sorry (((without))) when u temove the filter/regulator and install a manul fuel regulator u have to have a return line Upgrade crank pulley (??? from where) ------- needswings - AFR gauge w/ boost connector (~ $427) -------that's is high unless it is installed High flow fuel pump ($323) ------- u said you already have a sl55 pump that will work. SC pulley upgrade? This is already a 65mm Eurocharged one ----- that should be fine u will have to play with fuel pressure to get afr's where you want them about 65 psi https://cimg5.ibsrv.net/gimg/www.cro...29e849bcbe.jpg on mine i have the vacuum not conected https://cimg7.ibsrv.net/gimg/www.cro...e7f3abaaac.jpg |
Alright, so you have an additional line to install (not just replacement of the current fuel filter/regulator). Fair enough.
I can't seem to find a crank pulley upgrade on Needswings without buying the complete set with PSK and such. I guess @NeedsWings removed if from the website? > https://www.needswings.com/asp-178mm-kit-psk178 I have not bought a new/upgraded fuelpump (yet). The AFR gauge pricing was based of Needswings' set: https://www.needswings.com/zeitronix...and-controller 272 + 124 (boost/vac sensor) + 4 (o2 bung) + 27 (wireloom kit, because nice) I see your edited post, so this is just an more aftermarket AFR sensor I suppose? More info on what you've got? |
,Eurocharged,, Rennteck,, MBworld,, may have a crank pulley I looked on ebay none there.
email needswings tell him what u want as a package he may split it up the pulley from the kit ,if u told him you wanted a,, fuel reg,, fuel pump ,,afr guage and crank pulley try it |
With my mods, and the best tires money can buy short of slicks, I still find it super easy to spin the wheels even in second gear - WITH limited slip. I don't know your car, but I know mine. Before I had LSD, when I was making a left or right turn after a stop light, it was dangerously easy for the car to fishtail its way around the corner while at the same time the "electronic stabilization control" program was doing its level best to compete with my attempted control inputs - truly spectacularly horrible. All fixed with LSD (not the drug). Expensive but beyond worth it.
(Post 945996)
Hey De55id, thanks for your post. I had replaced the belt with the green one, the moment i got the PSK (option when you buy it), so it shouldnt be stretched yet.
An LSD is an interesting mod. Do you think the standard is not capable of keeping the wheels straight with so much power on the regular diff? A new fuelpump should be doable. Any tools to figure out if the fuel ratio is OK (through obd for example)? Thanks |
And thats when my Eurocharged 65mm pulley failed. 18000km on the odo, installed since 1 february.
https://cimg6.ibsrv.net/gimg/www.cro...dbc4c015c4.jpg https://cimg8.ibsrv.net/gimg/www.cro...5532646df9.jpg |
