Smaller water pump pulley needed. Bought used 185mm pulley
Old Oct 8, 2020 | 11:51 AM
srt6Master's Avatar
Default Smaller water pump pulley needed. Bought used 185mm pulley
Hey, everyone
I bought a 185mm pulley used and can not find a smaller water pump pulley anywhere so I can make this work. Does anyone know where I can get a smaller water pump pulley for our cars?? Your help is greatly appreciated. Thanks!
Old Oct 8, 2020 | 09:41 PM
waldig's Avatar
Default Re: Smaller water pump pulley needed. Bought used 185mm pulley
Who made the 185?? I had two detonate for me, not good stuff. Woody
Old Oct 10, 2020 | 12:46 PM
Morphh's Avatar
Rob at needswing will have smaller water pump pulley
Old Oct 15, 2020 | 10:35 PM
srt6Master's Avatar
Hi guys, thanks for the information. i got a smaller water pump pulley to make the 185mm work but i.dont know who made the pulley as I bought it used
Now I have a new issue. the car runs and shift when driving normal but when I am wot in all gears right around 5500 rpms it's like I'm bouncing off a rev limiter and wont shift or let me go past it, if I let off the gas it will shift. I have no ECU tune do you think that could help?
Old Oct 15, 2020 | 10:37 PM
srt6Master's Avatar
Old Oct 16, 2020 | 06:23 PM
As I recall LET made those pulleys, they also made the small idler pulley being that had bearing failures due to the high speed and load on it.
If I am wrong I apologize to the late LET.
Old Dec 21, 2020 | 05:08 PM
blackpepper's Avatar
You running a 185 without a tune listen you not shifting at wot because the car is actually leaning out trying to save itself guy get a tune for you car before you blow it up
billvp
Apr 4, 2021 09:55 PM
No2fast
Jul 22, 2017 09:36 PM
scsponger31
Aug 4, 2010 08:06 AM
amg-jerry
Sep 16, 2008 07:55 PM
ShawnQ
Jan 10, 2008 03:04 PM
