All components of SRT6 supercharger.
Old Jan 11, 2022 | 08:56 AM
ku95's Avatar
Default Re: All components of SRT6 supercharger.
Originally Posted by srt6prbk
did your oil leak got fixed with new bearing?
Unfortunately not yet, but I am using another used supercharger from ebay.
Spec. of the needle bearing is
In dia. : 25mm, Out dia. : 37mm, Depth : 28mm.
I found D:23mm and D:30mm which In/Out is same.
But could not find D:28mm.
Can you find the original size?
If we can not find D:28mm, D:23mm can be alternative.
Old Jan 11, 2022 | 11:57 AM
srt6prbk's Avatar
I never took out that bearing when it started leaking, just used a new oil seal with 2 springs inserted, been 2 years and 30,000 miles with 62mm pulley and hundreds of pulls. still bone dry. knock on wood
But If I can find the oem size will let you know
Old Sep 13, 2024 | 03:24 PM
jerrytaskila's Avatar
Does this part have a name and can i get one from somewhere?
Old Sep 13, 2024 | 04:30 PM
Try contacting Needswings.
Old Sep 17, 2024 | 05:28 PM
srt6prbk's Avatar
thats not available anywhere
but it can be repaired with brake lining
Old Oct 20, 2024 | 12:28 PM
srt6prbk's Avatar
scrap all the lining , then use 1/8 or thinner brake lining and cut it to fit, then use adhesive for lining, then sand down the part that sticks out, until leveled . did that years ago a still working perfect. I think I have photos
AutoArcheologist
Jul 17, 2019 06:15 AM
TNtech
Apr 12, 2018 11:14 AM
BrianBrave
43
Feb 18, 2012 01:22 PM
BLKFIN
Jan 31, 2010 10:40 PM
TexasCharles
South Forum
Aug 17, 2008 05:46 AM
