Help on cleaning engine area?
Old Feb 18, 2007 | 03:36 PM
nox1s's Avatar
Default Help on cleaning engine area?
Anyone know how to clean the engine area properly? I don't really know what you can/can't touch. I've heard that there are some sensitive wires/sensors/etc. that I don't want to break. It's getting pretty dirty in there!
Old Feb 18, 2007 | 05:14 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Help on cleaning engine area?
no issues and i wash mine monthly. i go to the .25 car wash... i use the soap & then rinse... followed up with a towel drying...
i do leave the engine running while doing so... turns out like new.
Old Feb 18, 2007 | 06:05 PM
Aero Blue's Avatar
Lightbulb Re: Help on cleaning engine area?
Ditto to Andrew and his advice and just don't spray directly on anything questionable, that's all and I've never had a problem cleaning my engine bay. BTW if the quarter car wash has the touch-free rinse, use it, as its always a lower pressure and has chemicals in it that generally leaves a spot free finish. Follow up the hoses and black plastic areas with your favorite tire shine and/or foaming product for that "bling" factor.
Old Feb 27, 2007 | 07:35 PM
midnightman's Avatar
I just want to get this straight...
It's safe to spray water directly onto the engine?
I too, am concerned about causing an issue by wetting a "questionable" area, as Aero Blue put it.
My question is, what constitutes "questionable" or sensitive areas.
And... Can this be done safely with the plastic engine cover removed? And how much water pressure is safe?
Old Feb 27, 2007 | 08:04 PM
PAULW's Avatar
I really don't advise washing the engine with the cover off, you could cover the air intake but I don't know if I would.
Old Feb 27, 2007 | 08:17 PM
oops... it's been so long since I took the cover off that I forgot it is part of the air intake. Please disregard that particular question.
Old Sep 18, 2007 | 01:10 PM
maxcichon's Avatar
I've been cleaning under the hood of every car I've owned since 1974 and gone the gamut on different products and procedures.
Simple Green is a pretty safe biodegradable detergent and makes a wonderful degreaser. It won't turn rubber or plastic gray and rinses clean.
These days I use a 50/50 solution of Simple Green sprayed out of a bottle, wait 5 minutes and rinse with a GARDEN HOSE! 40-50 psig of water is all you EVER want in the vicinity of your engine and it's many triple seal electrical connectors. They (MB) designed these connector boots with the intent of 100-150 MPH air/water mix at atmospheric pressure. NOT a 400 MPH directed spray @ 2,000 psig. I learned this lesson well on my '76 Caprice, one connector leaked, filled up and held water for 2 days until I found it. It was the Throttle Position Sensor and made the car run like it had 5 cylinders until it was dried out. Today's engines and associated electronics are much more prone to problems than in the olden days. No reason to add to it.
Old Sep 18, 2007 | 01:13 PM
maxcichon's Avatar
P.S. to my last post:
NEVER wash an engine immediately after operation. It should be at ambient temperature.
Old Sep 18, 2007 | 02:37 PM
MMZ_TimeLord's Avatar
I had the rear differential and entire under carriage as well as the top side of the engine bay steam cleaned a few weeks ago... looks like it rolled off the showroom floor.
Cost = $138 ... this was for the rear diff area, front underside and top side of the engine bay and a premium car wash.
Not too shabby when the regular cost for the rear diff, underside and engine area is normally $178 without a car wash.
Old Oct 14, 2007 | 10:31 PM
golfdude's Avatar
I wanna see pics of the clean underbody MMZ.
Old Oct 14, 2007 | 11:12 PM
CrossfireLTD's Avatar
Cool Re: Help on cleaning engine area?
Also if you get any water in any electrical contact points, you can use WD-40 to dry out the contacts. The name WD-40 was actually derived from '"Water Displaced on the 40th test".
Old Oct 15, 2007 | 04:45 AM
XFireHammer's Avatar
Here is very good Engine Detailer Link:
http://www.autopia-carcare.com/inf-engine.html
This procedure takes into account the preparation that some may wish to use, to protect specialized Engine Components.
I personally use the "AUTOGLYM" Engine and Machine Cleaner, but there are probably a multitude of products that can degrease an engine and the engine compartment equally well.
Good Luck,
XFH
Old Oct 15, 2007 | 07:31 AM
maxcichon's Avatar
I'm sorry Andrew, but I beg to differ... No high pressure jets!
http://www.dccarcare.com/tipowk/tipowk13.html
PimpDaddy
Sep 29, 2016 11:55 PM
reiji
Oct 15, 2015 10:50 PM
Indelibility
Aug 27, 2015 10:21 PM
BrenLW
Aug 5, 2015 04:53 AM
cjfine
Jul 20, 2015 11:58 PM
