Need engine detailing help
Hi guys this is related to my V8 conversion thread. I want to do some major detailing to the new engine before installing it. It is currently on my engine stand, The CL500 engine is pretty nice considering it only was on the road for 12 months before the car it was in was totaled. The aluminum has some ugly water spotting on it. I need to know the best way to clean this engine to like new condition and then figure out a way to protect it so that it will stay this way. The water spotting looks a little like whitish corrosion. I am thinking that an acid based cleaner would clear this up and tnen maybe a statin clear engine paint would keep it looking new?
I will also be painting or powder coating the valeve covers and doing something special to the engine cover (haven't decided what yet, silver paint, body color paint, synthetic carbon fiber?)
Originally Posted by andrew
i would begin with a mild degreaser... and a brush.
I was thinking CLR myself...try it in a small inconspicuous area and see what it does.
Simple Green may be a good idea also - but I've noticed it can 'spot' if the aluminum on the engine is hot (which wont be the case in your scenario...but I'm not sure what it does when the engine is cold).
A lot of the cars at Bonham had a ton of aluminum oxidization on them...
SQ
SQ
SQ
SQ
Ok, I just did a little research and it is oxidation. From what I read the best cleaner that also brightens the aluminum is Phosphoric acid which I found is used by truckers, and even sailors to clean aluminum masts. I will try to find some of this stuff. If this works, I will need to find something to prevent it from coming back. I once had some High heat ceramic clear that I think would look good. I will try to at least post the "before" pictures tomorrow.
Because of the engine cover, most of the engine is inconspicuous, but since it is currently on an engine stand, everything can be cleaned. If would probably be easier to clean if I know what it is I am trying to remove. So you think it is aluminum oxidation?
I've used this stuff for years:
http://www.orisonmarketing.com/corro...luminator.html
Just follow the directions. Since it IS acid based, make sure that you rinse thoroughly and dry it off right away.
It will not leave a "shiny" surface. It will be a "bright" surface. Very uniform, but white in appearance. To make it shiny, polishing is the only way to go.
Best, and thanks for the Posi-Quiet recommendation. No dust is very cool.
LantanaTX,
Gald to hear you like the Posi Quiet pads. They are great pads! It is only a matter of time before others on this site discover them.
xfireohio
Jul 20, 2020 12:03 AM
northwest_crossfire
May 30, 2016 05:19 PM
reiji
Oct 15, 2015 10:50 PM
