Cleaning your engine bay area
Old Jul 18, 2004 | 02:32 PM
Doc's Avatar
Doc
Default Cleaning your engine bay area
Take it from an old hand that has owned 104 cars, many of which have been show cars, this is the way to clean your engine bay area.
For older cars (1915-1980's) you should cover the distributor with a plastic bag first. For cars after that era it's usually not necessary if you don't get too crazy with the water around the distributor. All other areas are built to withstand mild amounts of water, such as the starter and alternator.
If your engine is fairly clean but just has a few greasy, oily spots or heavily soiled areas like around the master brake cylinder area, just spray a little Simple-Green on it first and let it sit while you're getting the garden hose out to use for rinsing it off.
Do not use a high pressure washer, it can disconnect some important things if you hit them wrong. Just use a normal garden hose and typical hand sprayer that people often leave on their garden hoses.
Rinse the engine bay area carefully and thoroughly, then use an AIR COMPRESSOR and hand air-nozzle to blow the water off everything. Do it as quickly as possible, then it won't spot or streak. Careful you don't drag the hose over your fenders and scratch them.
NOTE: if you want the bottom of the engine clean, use some Simple-Green on the pan area as well.
If you really want to put a shine on certain areas use your typical paint polish or wax for the chrome and shiny/smooth painted surfaces.
Any area's that are still wet will dry quickly when the engine gets hot.
NOTE: If you should accidentally get the ignition wet and the engine won't start, as normal, immediately. You can either open up the distributor and blow the water out of the inside of it or you can simply wait an hour or so and it will dry by itself.
Your done! Now go for a ride and enjoy your car.
Your old friend,
"Doc"
Old Jul 19, 2004 | 12:47 PM
Cyril Baldwin's Avatar
Default
Doc, can you mark in your pic where the distributor is? Thanks.
Old Jul 19, 2004 | 05:28 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default
i head to the quarter "diy" car wash. i wash the engine with the soap selection then rinse and towel dry... a perfectly clean engine every time w/o any side effects. no need for chemicals... it's a newer car... just normal road dirt and dust. cheers!
Old Jul 20, 2004 | 08:53 AM
WesMichaels's Avatar
Default
There's no distributor. There are 6 coil packs. 3 on each valve cover. One per cylinder. Two plugs per cylinder.
Old Jun 28, 2006 | 07:17 PM
dirtboy's Avatar
Default Re: Cleaning your engine bay area
Doc, if I wanted to take the engine cover off to clean under it as well, would I just need to cover the intake or is that not recommended?
PimpDaddy
Sep 29, 2016 11:55 PM
reiji
Oct 15, 2015 10:50 PM
Indelibility
Aug 27, 2015 10:21 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
