Tvt250
Old Apr 16, 2008 | 09:59 PM
  #41 (permalink)
Mabs's Avatar
Default Re: Tvt250
Originally Posted by TVT_DESIGN
The biggest thing is the addition of larger injectors. The stock ones run way too lean in the Upper RPM band for any serious power.
With our airbox mods we should still be seeing a little over 250, but with the addition of the CAI probably closer to 260HP.
Everything will look much better with a Dyno and some video.
Anthony
those numbers seem WAY to large....Ill believe it when I see it
Old Apr 17, 2008 | 09:08 AM
  #42 (permalink)
downwardspiral's Avatar
Default Re: Tvt250
with the modified stock airbox, will dealerships be able to tell the car was modified? I'm intersted in the package, and your only 2 hours away from me, but Im only concerned that I will lose warranty coverage.
Old Apr 17, 2008 | 10:07 AM
  #43 (permalink)
xfire123's Avatar
Default Re: Tvt250
what kind or brand of dyno are you using??
Old Apr 17, 2008 | 11:22 AM
  #44 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Tvt250
By opening the hood and looking at the engine it will be hard to notice any changes unless you really look for them. Of course if the dealer started pulling apart your engine they would notice different injectors (if they knew) and the modification in the inside of the airbox. This is about as stealth as you can go though.
We are using a Mustang AWD Dyno
Old Apr 17, 2008 | 12:26 PM
  #45 (permalink)
Maxwell's Avatar
Default Re: Tvt250
doesn't really matter what dyno you use, as long as we can see a change in power from the base line.
Old Apr 17, 2008 | 05:03 PM
  #46 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Tvt250
Due to some family issues the Dyno hsa been pushed ahead to Tuesday. We'll be away till monday and will be back Tuesday with lots of good information.
Old Apr 17, 2008 | 05:11 PM
  #47 (permalink)
Hugo's Avatar
Default Re: Tvt250
Airbox modifications will not alter your warranty. DC has told me that as long as I dont play with the internals they will cover me for the factory warranty.
With all the mods on my car I have NEVER has an issue, in fact they are very happy that someone is oplaying with the vehicle. If you crack the engine THEN you may have an isssue. Even my Powerchip ECU is fine by DC
Old Apr 18, 2008 | 05:48 AM
  #48 (permalink)
Default Re: Tvt250
nice, thanks for the info
Old Apr 20, 2008 | 11:57 PM
  #49 (permalink)
newCrossfire's Avatar
Default Re: Tvt250
this is very true i was very hesitant to take my car to dealer because of my intake. but i needed an oil change and its free from the dealer. soooo took the car in...when i picked it up they gave me my inspection sheet... no problems what soever for may air filter the just crossed out the box and wrote in K&N.
Old Apr 22, 2008 | 12:47 PM
  #50 (permalink)
Default Re: Tvt250
any news? I've been waiting for the dyno sheet
Old Apr 22, 2008 | 12:48 PM
  #51 (permalink)
Default Re: Tvt250
ditto. im waiting on this because im split between buying parts for the muscle car or for the crossfire???
Old Apr 22, 2008 | 01:10 PM
  #52 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Tvt250
We're here now. I posted some details in the dyno thread. 208 is our best so far on awd mustang dyno. Usually a 20 percent loss, comes out to 260. This is with the modded air box, tune, and injectors. Sorry we didn't hit the 250, maybe we'll change it to TVT260.
Old Apr 22, 2008 | 03:12 PM
  #53 (permalink)
stevieb's Avatar
Default Re: Tvt250
Hi Anthony, well done getting those figures that must be some grin you are carrying
the car you are using, has it still got the standard exhaust or your TVT Exhaust?
Old Apr 22, 2008 | 03:23 PM
  #54 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Tvt250
Our TVT Exhaust is a completely removeable system, for the dyno it's the stocker.
This dyno is with only modified air box, ECU tune, larger injectors, and AIR pump block off plates (zero HP gain, I guarantee that).
No modified thermostat, pulleys, exhaust, plugs, ignition wires, or any of the other goodies.
Old Apr 23, 2008 | 06:32 PM
  #55 (permalink)
x justin's Avatar
Default Re: Tvt250
I already made my own intake, so for $800 you would tune my ECU and mail me back everything for the bigger injectors? How hard is it replacing them (instructions online somewhere?).
Old Apr 23, 2008 | 06:49 PM
  #56 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Tvt250
We've cut a deal with another owner with an intake already of 750.00 for ECU tune and injectors.
Full color install with injectors. About an hour to take out and replace.
Old Apr 23, 2008 | 08:11 PM
  #57 (permalink)
X-FIREcmv's Avatar
Default Re: Tvt250
ill tell you guys this. if you guys get a crossfire limited runnin somewhere in 13.8-14.0. ill buy this kit in a heart beat. no questions asked. i have the money waiting. just waiting to see if someone will get it into that range
Old Apr 23, 2008 | 08:45 PM
  #58 (permalink)
psuperti's Avatar
Default Re: Tvt250
That's not bad. If I can get a hold of a good shop I will go for the injectors and send you my ECU. I had the Upsolute for 91 octane. So does it matter what octane I use? Because TX has 93, so that's what I use now.
Old Apr 24, 2008 | 05:00 AM
  #59 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Tvt250
I can guarantee with the HP we're putting down now we will not crack the 14.0 barrier with stock drivetrain, weight, etc.
It's more realistic to shoot for a trap speed then an E.T. If we were to gut our interior and throw on drag radials we would deffinately be there, but then would that make our product anymore useful? They way this car is set up 275 HP is probably where you want to be to crack 13.999 in a 6 speed.
Old Apr 24, 2008 | 07:39 AM
  #60 (permalink)
x justin's Avatar
Default Re: Tvt250
I'm thinking a little over a half second gain in the quarter mile. I couldn't get any more than a 15.0 out of my autostick, so a 14.5 or so would be a realistic expectation for me.
