Couple NA Tech questions
Originally Posted by HDDP
That in itself is a major feat with the intrusive TC... How did you disable it to drift / slide the car ?
not to mention continentals are shitty shitty hard tires, doesn't take more than a clutch kick to initiate a slide
we recently hosted an event at turner field, and on the uphill sections of the track the car wanted to nothing but understeer since its open diff... but as soon as the track transitioned to downhill, give it a clutch kick and the car just slides... its incredibly balanced and rather well suspended for a stock car.. it had less body roll than most of the track prepped cars out there (mostly s13's)
i need a spare diff to weld to fix the open diff problem
and im not saying that as an out... my car note is 580 a month... and i pay 5k a year in insurance. just to give you an idea. my dad is giving me his c6 z06 and insurance is like 6k.... so you can almost see my justification for questioning why... lol
now back to the turbo setup....
i can run the manifolds to the front of the motor with no problem, but i have to get new ac lines made.
i found the perfect intercooler
so im trying to figure out what to do radiator wise so i can run one single charge pipe to the tb..
maybe i'll toss the one off of my 240 on the crossfire... my koyo is slightly shorter in height and i could possibly run an oval charge pipe to clear the rad support.
most everything exhaust related will be ceramic coated to eliminate the horrid underhood heat problem these cars have. i can hopefully solve that with the 2 pusher fans
Originally Posted by Maxwell
if you read the shop manual, it clearly shows, two, 4 bolt mains, and two 6 bolt mains on the center of the crank support. sounds like it can handle 400hp easily.
the crank is the strongest part of any motor
it comes down to piston design and construction, ringland size, spacing, depth, etc
connection rod design and construction
im more worried about popping a ringland than i am about throwing a rod
how many tickets/accidents do you have on your record?
Originally Posted by Larsony
I think it is safe to say that he practices drifting on public roads.
sorry, not that immature. we do that on private tracks only
1 speeding ticket... 18 over
1 too fast for conditions
1 seatbelt ticket
1 accident ( i was hit by an illegal and spun into an illegal, they both left the country and i got stuck with the accident)
thats it and i have 7 cars insured and they dont give me a discount... time for a new insurance company
lol i know
im just pissed about this turbo thing
if they arent here tomorrow im gonna kill someone
i do have a couple of single's sitting around i could probably use...
blah
blah
Thanks I may check it out. The problem isn't manifolds I can make those. It's just space. There isn't any
xfireon20z
Sep 10, 2015 04:27 PM
