smog/secondary air pump failure...how can i trick the ecu...
Old Dec 14, 2008 | 08:08 AM
ryan48's Avatar
Default smog/secondary air pump failure...how can i trick the ecu...
I have determined it is sadly the pump that went bad. I found a benz pump for the slk 3.2 but chrysler says its a diff part....not sure if it is or not...I'd like to simply either delete it via the ecu or find a way to make the ecu recofnize it as functional. Any ideas?
Old Dec 14, 2008 | 08:40 AM
Moparrbust's Avatar
Default Re: smog/secondary air pump failure....how can i trick the ecu....
replace it with a new one..............that will make the ECU think it is functional.
Old Dec 14, 2008 | 09:54 AM
TVT_DESIGN
Guest
Posts: n/a
It's the same pump. You can just disconnect and buy our Block off Plates or make your own.
Old Dec 14, 2008 | 12:43 PM
ryan48's Avatar
The block off plate is a good idea, but if I remove the pump won't the engine light continue to trip? If so, how do I solve that issue? I just don't see the sense in replacing a 800 pump that serves absolutely no purpose as it passes emissions without it. Thanks for any help you can provide
Old Dec 14, 2008 | 12:53 PM
TVT_DESIGN
Guest
Posts: n/a
It won't help the CEL problem, but you won't have a faulty pump hooked up to your engine anyway.
If you want another Pump, I have a few at the shop I can sell you. All in working condition, mine only has about 5k on it.
Old Dec 14, 2008 | 12:57 PM
ryan48's Avatar
What kind of deal can you make me, I'm def intersted. Its even 500 from MB and 200 on ebay, but if I can get an oem one I'd prefer that. Just let me know and we will work something out
Old Dec 14, 2008 | 11:01 PM
manisusmc's Avatar
Default Re: smog/secondary air pump failure...how can i trick the ecu...
try taking the ground wire off and cleaning it well.
i did this on my car and it has not tripped the code any more since
Old Jul 3, 2013 | 07:15 AM
RobF's Avatar
I'm wondering, my pump just went bad, so I had this idea. There is a shop in my town that rewinds electric motors, including new brushes, etc... They rebuild them if you will. I thought this may be a viable solution to one's Air Pump woes. I plan to try it at least, before throwing down for a replacement. Any thoughts or experience in this area are welcome.
Valk
Jun 22, 2025 09:15 PM
MiamiTVR
Jan 30, 2016 02:15 PM
cppeabody
Sep 15, 2015 08:43 AM
81's
Sep 13, 2015 04:34 PM
crmnal
Sep 6, 2015 08:07 AM
