Dual Exhaust Bung
Old May 2, 2011 | 05:02 PM
kolevski's Avatar
Default Dual Exhaust Bung
I've had an idea of creating less welds in our exhaust systems.
I'm not sure if one of these exists somewhere but I cant seem to find one, any of you fabricaters wanna try and make one up?
ebayalp-88310 | Flickr - Photo Sharing!
Sort of like that so you can screw it into the original O2 sensor then have 2 sensors screwed in side by side if ya get what I mean.
Just an idea.
John
Old May 2, 2011 | 06:52 PM
Default Re: Dual Exhaust Bung
I don't see any external threads to install into the exhaust pipe. Also I would think the sensor should be in the exhaust stream. I am not sure of the benefits you are talking about.
James
Old May 2, 2011 | 07:03 PM
kolevski's Avatar
Sorry James I should have been abit clearer.
If you look under your hood and see your headers on each side you will see an 02 sensor screwed in on each side,
What I'm trying to get made up is like a 'Y' Pipe bung that can screw into one of the existing bungs on the header and then being a 'Y'
design 2X 02 sensors can be screwed in, rather then welding another bung to fit another sensor.
John.
Old May 2, 2011 | 08:27 PM
MikeR's Avatar
The O2 sensor needs to be in the exhaust stream.... I am pretty sure they would not work, or give correct readings, if mounted as you suggest.....
Thinking out of the box is a good thing.....
blackpepper
Dec 18, 2021 06:17 PM
TerryR
Dec 13, 2019 03:27 PM
cuziamninja
Oct 5, 2015 10:39 AM
Sep 28, 2015 07:40 PM
RacerXofFL
Sep 15, 2015 05:00 PM
