Spark Plug Recommendation
Old Sep 3, 2017 | 06:02 PM
SrWilliams's Avatar
Default Spark Plug Recommendation
I apologize to everyone and I swear I have been researching this forum and others trying to get a simple answer to what spark plugs to purchase for my 2007 base crossfire. Most everything I have read gets to technical on specs. Or, everyone say get stock---and as a knucklehead I do not even know whereto get the stock plugs from (hopefully not the dealership. Can someone please just recommend to me the best plugs to get and where to purchase them from.
Thanks everyone
Old Sep 3, 2017 | 06:06 PM
Default Re: Spark Plug Recommendation
Just order a set from Rob at Needwings : NeedsWings Performance Products. NGK Iridium IX Spark Plug Set
Old Sep 5, 2017 | 01:25 PM
SrWilliams's Avatar
Thanks ala-xFire.
I am now placing my order as you recommended
Old Sep 11, 2017 | 03:47 PM
Eco's Avatar
Eco
I use NGK laser iridium plugs. See pic below
Old Nov 16, 2017 | 02:17 AM
Rsoe's Avatar
I used Bosch iridium. working just fine.
Old Nov 16, 2017 | 10:07 AM
Padgett's Avatar
Where do you gap them ? Merc seems to want .031 (.8mm) which seems awful tight for an electronic ignition. Have also seen .040 (1mm) for XF.
Old Nov 16, 2017 | 10:09 AM
According to Rob at Needswings : Recommended gap is 0.039"
Old Nov 16, 2017 | 02:00 PM
This is a European car with the recommended gap of 1 mm which is of course .03937", but who is going to quibble if it's at .040".
Old Dec 7, 2017 | 11:20 PM
lovecross's Avatar
As I recall,, my oem plugs had M/B emblem on one side & NGK on the other.
Old Dec 8, 2017 | 09:30 AM
I have a set from an NA and they have a blue MB logo on one side and they are Champion plugs KC10PYPB4. Replaced with NGK BKR6EIX-11.
Old Dec 9, 2017 | 12:46 PM
Padgett's Avatar
.040" makes a lot more sense though is still tight for a transistor ignition. original Reatta 3800 with Magnavox was .045" but with Delco ignition like mine, .060".
