Air con not working
Old Jun 13, 2021 | 10:31 AM
marvo's Avatar
Default Air con not working
Hi all, I have a stock 2004 coupe, the air con is not blowing cold at all, had it serviced but still no cold air, compressor clutch works fine when air con selected, disconnecting the pressure switch switches it off ok and back on when refitted, the off loaded torque of the compressor wheel when spun by hand feels quite low despite system charged and the same as the used compressor I have in the garage. Everything seems to point to the compressor just not pumping the gas around, perhaps the drive has sheared? I would expect compressor to lock up if failed but perhaps they are designed to shear if seized? The car was sat for around 8 years before I got it and the air con has never worked for me.
Any ideas before I change the compressor? Thanks guys, Marvo.
Old Jun 13, 2021 | 11:04 AM
Default Re: Air con not working
Does it blow warm air or ambient temperature air, are the two heater valves closing off properly? Does the engine fan start up when the AC is selected?
Old Jun 13, 2021 | 11:10 AM
marvo's Avatar
Fan fires up when AC selected, heater control valves working ok, when I feel the LP and LP lines from the compressor they are ambient temperature they don't cool down one bit so I am thinking no flow from the compressor.
Old Jul 5, 2021 | 05:49 AM
giaiu79's Avatar
the mechanic tried to make current directly from the battery to the compressor and does not start the same. according to him he insists that the compressor is wrong. you think?
Old Jul 5, 2021 | 08:51 AM
Doc78's Avatar
Before replacing the compressor I would wire it directly to the fuse to see if the clutch engages.
it could be many different sensors or pressure. Pizza guy listed them on a different thread.
martyfa
Aug 14, 2021 09:05 PM
Wimbledon37
Jun 17, 2020 02:24 AM
Scotto97
Aug 25, 2013 01:10 PM
waldig
Jan 11, 2012 06:23 PM
english_bob
Jul 29, 2004 02:51 AM
